Question about Samsung Black Back Cover Case For Rock Nakedshell Sumsung i9500 GALAXY S4
Is there only one way to insert a simcard in a samsung s4
I have just got a new s4 samsung put the battery in and the sim card it is charging how do i get it to work can the sim card be in the wrong way
  • 179 Answers
Unfortunately yes, it can be inserted upside down.
Posted on Nov 10, 2014
How do I open the back of a S4 Samsung galaxay cell phone
Samsung Galaxy S4: How to open back battery cover:
1) Flip the phone over so you see the back cover..
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-5.jpg 2) Locate the notch on the side of the phone with your fingernail and pull the cover easily up to unlatch that area and all areas around the phone.. With one hard pull you can easily take off the whole cover.. don't be shy, your Samsung phone is sturdy enough to handle it.
All the blue arrows in the below image shows where the cover clicks into the inside of the phone to keep it closed.
open-back-s4-samsung-galaxay-cell-phone-kyzl0pi20tqzz121bvlihxv0-2-9.png 3.) when you need to put the cover back on the phone.. place the cover over the back part of the phone, noting that the camera hole in the cover goes at the top..
Then grip your left hand on the left side of the phone and your right hand on the right side of the phone.. apply pressure to each side to click the latches to the phone locking it in place.
Afterwards, run your fingers along the back sides of the phone to see if there are any bulges (a latch may not have clicked in place). Either apply pressure there to click it into place or you may have to take the cover off again and try again.
It's very simple and easy once you get the hang of it.
How to Open Samsung Galaxy S4 Back Cover Insert Battery SIM Replace Back...
Bending the back cover will not damage it because it is plastic.. unless you bend it to crease it. Below is Samsung's durability test.
https://www.youtube.com/watch?v=UrhCz6PnT78
(you may need to copy and paste this link to make it work)
Jan 18, 2016 | Samsung Galaxy S 4 GT-i9500 Smartphone...
Free imei unlock codes
Hello. I couldn't find any reliable and free unlocking source for a Samsung Galaxy S4 from online. Most of the free offers were looking to be scam with many negative reviews. If you want to unlock your device safe, you need to spend something for it. For example, you can visit Unlock-Zone.com and get the accurate unlock code for your Samsung Galaxy S4 at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S4 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S4 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S4 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S4.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S4 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S4.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung Galaxy S4.
SOURCE: MobileUnlockGuide.com
Aug 18, 2014 | Samsung i9500 Galaxy S4 16GB Unlocked...
How to unlock s4 sgh-m919-ud?
Hi. What is the exact model of your Samsung phone? If you want to unlock your Samsung Galaxy S4, you can unlock it safer and easier using unlock code. You can get the accurate unlock code for your Samsung Galaxy S4 from ProUnlocking.com at affordable cost.
Method 1:
Method 2:
Jul 25, 2014 | Samsung Cell Phones
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
It says insert simcard
Try taking the sim card out and putting it back in. the sim card is generally located under the battery.
Apr 15, 2012 | Samsung Wave 525 Cell Phone
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
Give me formate code for samsung C5212
list of samsung codes for u
Quote:
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong
network SIM and insert a half of it,(pic2501)
so it won't ask for
network password and shows "Insert SIM" message.(pic sam25020)
Now put the battery ,and switch the phone on .(phone shows "InsertSIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone isstill asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable
networklock By typing: #7465625*638*00000000#(hash 7465625 star 638 star8zeros hash)
Phone is unlocked (check with *#7465625#)
For Model:
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# andhit the Call button. Turn off and insert another Simcard. Turn on. The code is00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) untilphone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter#0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Youwill get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
d500 - #*7337# - ( but not in the newer software versions )
update 04/02/07
1. If you have changed your phone password, change your password back to thedefault 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, thenSIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone islocked to
3. When Incorrect SIM error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey.
5. From the menu that appears, select the Malloc Fail option. This will rebootthe phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization"or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK mentioned earlier getsswitched back on)
10. Completed. You have now unlocked your phone.
tested on e900 and d900 phones - may work on similar models but not sure
ps this will work with your new sim but if you try anither sim not used in thatphone bofore it will need code doing again
Apr 03, 2011 | Cycling
INSERT SIM
If the display says "Insert SIM," it means that the phone has no contact with your subscription card (SIM card) that is inserted in the phone. We recommend that you remove the battery and the SIM card, and clean the connectors on the SIM card and the phone with a soft brush, cloth or Q-tip moistened with any type of unflavored colorless alcohol.
At the same time, check that the card is not damaged or worn in any way, in that case, the connector may not align with the connector in the phone. Please contact your operator / carrier for a new SIM card.
Sep 21, 2009 | Samsung SGH-c207
SGH-U700 mobile Phone simcard does not fit
Hi, DONT CUT SIM!
Sim cards on the samsungs slot into sim reader which is found under battery. If you remove the battery you should see where it goes. The slot you are referring to sounds like the memory card slot which is an expansion slot if you want to increase the memory size for file storage. Hope that helps?
Apr 30, 2009 | Samsung SGH-U700 Cellular Phone
Sim card
THIS PHONE DOESN'T USE A SIM CARD.....DUHHHHHHHHHHHHH!!
Mar 22, 2008 | Samsung SCH-a650
Samsung Black Back Cover Case For Rock Nakedshell Sumsung i9500 GALAXY S4 Logo
463 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
