Question about Lifespan Fitness Treadmill Walking Belt Lubricant Lube
DC-6 error code .
As soon as I turn my 1 mo old treadmill on I get an error code of dC-6 and it will not run? Hoe can I fix this?
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
Error code AC-6
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION ...ERROR 1-2: AC SERVO ERROR - MOTOR IS OVERHEATING (SPEED RESTRICTED ... error codes listed by category: treadmills, bikes, elliptical trainers.
[PDF]Precor Error Codes
I have Kettle pacer treadmill,when I press start button the display shows error DC 6 and belt does not move
have you kept the belt regularly lubricated ?
can't find this error code in manual
Nov 25, 2014 | Kettler treadmill Pacer
DC-6 error on Lifespan Treadmill
Follow attached link to see user manual.
Unplug treadmill.
On page 13 of the users manual, read step 5 part B regarding the wiring harness. Unplug and plug back in each of the connectors of the wiring harness. Plug the treadmill back in to see if it now works. https://s3.amazonaws.com/lifespanfitness/pdf/Manual_TR4000i.pdf
Jul 30, 2014 | Lifespan Fitness TR4000i Folding Treadmill
As soon as my treadmill is powered on I get an error code of dC-6, and it won't function, how can I fix this?
Hallo,
Fisrt of all, i hode like to thank you for you kindness.
I have more details of the machine.
Marc: GREEN MASTER
Model: 928
i Hope that can help you.
Thanks again
Sincerely
Carlos Silva
Feb 14, 2014 | Lifespan Fitness Treadmill Walking Belt...
York treadmill t-801la T780 platinum error code 1
see the comentary ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.7099b61f-975c-463c-9361-522952e1c927.gif
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 08, 2013 | Exercise & Fitness
Sportsart 1200 treadmill E-6 hoe do you recalibrate it?
read the instruction under HOOD motor and proceed according . OTherwise go to the instr. manul and follow the steps for how to enter the s. calibration
if you do not have the manual go to www.fitness.manualsonline.com
God bless you
Nov 30, 2012 | Exercise & Fitness
E1 error code
Lets eliminate the motor first, unplug unit remove motor shroud fin the 2 leads from motor to lower board. Connect a 18v DC battery to the leads this start the motor to move at approx. 1 mph if it does motor is good,if not you may worn motor brushes worst case open connection in the motor.
Now if the motor is good then reconnection the leads and plug in unit the lower board should have some LEDs lit up. Now find the LED that says PWM start unit if that light should start to flicker then the upper board and wire harness are work properly. Turn off the treadmill then turn it on and with a multi meter insert the leads into the connectors that go to the motor, then put the meter on 200v DC then start the treadmill you should get a reading 5 to 10v DC if you get 0v DC then the board will need replacing
Jul 07, 2010 | Cardiozone Supersport Hr Club Commercial...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Lifespan Fitness Treadmill Walking Belt Lubricant Lube Logo
56 people viewed this question
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Mike
Mike
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
