Question about Siemens Washing Machines
Error code e43 on the siemens washmashine s 1676
I have a problem with this washmachine e 43,i have replaced the brushes but still e43,how to reset this washmachine
4 Suggested Answers
  • 240 Answers
SOURCE: e43
unless it says motor control then its the one up front
Posted on Apr 23, 2008
  • 1527 Answers
SOURCE: I have a Frigidaire LTF2140ES1
hello doug just looked a error code e43 board communication problem
shaun
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Error code E43 on display of WPRB9220DCC GE Washer
This is the beginning of a leaking seal in the gear box. Some units have a pan to catch the leak from getting to floor. Seal needs to be replaced, otherwise gearbox will fail (lot more $$$$)
Posted on Mar 16, 2009
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  1. Turn off the machine (dial to 0)
  2. Open the door
  3. Turn on the machine on first program
  4. Close the door
  5. Turn off the machine
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
Oct 08, 2016 | Siemens Washing Machines
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
Jul 11, 2015 | Frigidaire 131763202 WASHER DOOR LOCK...
Zanussi washing machine fs1255w green end light flashes 5 times what is this error code
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
Examples:
Alarm E43 (problems with the door safety interlock triac) will be displayed as follows:
• four flashes of the END OF CYCLE LED indicate the first digit E43;
• three flashes of the START/PAUSE LED indicate the second digit E43;
So, error code E55 as you specified does not exist. Any how, family error code 5 (first digit) means problem with motor. Error code could be E51,E52,E53 and E54.
Possible causes:
- faulty motor
- motor brushes (very often)
- faulty tachometer (integrated in the motor but is replaceable)
- faulty electronic (Motor power triac short-circuited or motor relay contacts sticking).
Dado
Jan 18, 2015 | Zanussi Washing Machines
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
Zanussi washing machine ZWF 14581 error code 43 is showing up. How can I reset the machine so that it works normally?
Zanussi code 43 states 'problem with the door interlock triac', sorry- likely service call ;-0(
Good luck
John C.
Oct 08, 2011 | Zanussi ZWF1430W Front Load Washer
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
Sep 14, 2011 | Washing Machines
Got an error message E43 model WPRB9220D0WW
E43 is for "excessive drive system brake time"
Reset with
1) unplug 3 seconds,
2) hold Power & Start to display "Jr",
3) cycle thru using the Custom 2 button (3 times) to display E43,
4) hold Power & Start to clear code to E00,
5) stop.
Jun 29, 2011 | GE Washing Machines
Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Jul 20, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
584 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
