Question about Staples 2x1 USB Peripheral Switch
Installation Software The link for software download is not in operation. Any suggestions?
Hp C6180 printer will not copy or scan
I have the same printer, and I just re-installed it a few days ago. I had just performed a clean re-installation of my Windows operating system to clear up my slow machine.
Assuming there's basically nothing wrong with your printer, I suggest that you un-install your printer, then download and reinstall the driver software like I did. Print this solution out while your printer is still working, & follow these directions.
First, follow this link to get to the HP software for your printer (Copy & Paste it into your browser's address bar):
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=1153494
Choose the appropriate Operating System for your computer from the drop-down menu.
Click on: Driver-Product installation software
Next, click:"HP Photosmart Full Feature Software and Drivers" link.
Next, Close out the "Your Input is valuable" popup window, should it appear.
Next, click on the link after "File Name:" to begin download. "Save File"
Now you have the most up-to-date drivers for your C6180 for your re-installation!
Now unplug your printer from power and USB connection to your computer.
Go to your Start menu, then Control Panel & select Add or Remove Programs & remove all programs related to your HP.
You should now have your old driver software un-installed. Now run the new Software that you downloaded and saved. It will take about an hour. Do not plug in your printer's power & USB cable until prompted by the installation software! If you select all the options available for installation, I'm confident that you will have included the scanner & Fax functions.
Good luck, Brian!
Feb 11, 2012 | HP PhotoSmart Office Equipment & Supplies
I need the software disc for my HP F 300 any sugestions
HP Deskjet F300 has F340 and F380 series printer which uses the same software.
Click on the link below and select the operating system to download the software.
Choose 32-Bit Operating system drivers from the list ( ex. Windows XP 32 bit )
Run the file once you have downloaded to start the installation.
Download Drivers
To know more about installation procedure,
For Vista Installation Instructions - Click here
For XP Installation Instructions - Click here
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 16, 2010 | Office Equipment & Supplies
How i can install my lexmark x1270
I suggest not to plug the Lexmark X1270 printer to your computer yet. If you have the installation cd, insert it in your computer and install the software. The software will also show you the steps on how to setup the printer itself. If you don't have the installation cd, here's the link for the available Lexmark X1270 drivers http://bit.ly/9Xw7bN. Choose the driver compatible with your computer's operating system. Download, execute the file and follow the instructions on the software.
You can also download the Lexmark X1270 User's Guide by clicking on this link: http://bit.ly/d2qaOa. Thanks
Aug 04, 2010 | Lexmark X1270 All-In-One InkJet Printer
After i run the installation disc,i get a message "printer files are missing.please try to uninstall and reinstall.
I suggest you unplug the printer from your computer and uninstall the Lexmark software. Here's the link to the Lexmark website to guide you on how to uninstall the software properly http://bit.ly/aNSG9i. On the page, click on How to Uninstall Lexmark Printer under Top Documents tab for the instructions. To reinstall the software, click on the link I provided again. Click on Downloads tab, choose the driver compatible with your computer's operating system. Download and install the software. Follow the instructions on the software. Thank you for choosing Lexmark.
Jul 19, 2010 | Lexmark X2600 InkJet Printer
I have a cracked installation software CD for Lexmark P4350. How do I replace CD?
There are Lexmark P4350 drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/9yASdX. Click on the Microsoft or Macintosh dropdown found below the page to choose the version of your computer's operating system. Then download and install the software. Hope this helps. But if you really need the installation cd itself, I suggest you contact Lexmark Technical Support to request for it. Thanks.
Jul 10, 2010 | Lexmark P4350 All-In-One InkJet Printer
LEXMARK X3550 PRINTER I DON'T HAVE THE INSTALLATION CD HOW I CAN INSTALL IT? i know the printer is functional
I suggest not to plug the printer to your computer yet. Download and install the software first. For the software, click on this link: http://bit.ly/aYhzo4. Choose the version of the operating system of your computer by clicking on the Microsoft or Macintosh dropdown found below the page. Download and install the software. Follow the instructions on the software. Hope this helps.
Jul 05, 2010 | Lexmark X3550 All-In-One Printer
I need to install my printer
I suggest not to plug the printer to your computer yet. Install the software first. You can use the installation cd that came with the printer. Follow the instructions on the software. NOTE: The printer is not compatible with Mac 10.4 and later. If your computer is running on Windows 7, download the Vista driver from the Lexmark website.
If you don't have the installation cd, there are drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/dvTkSf. Click on the Microsoft or Macintosh dropdown to choose the version of your computer's operating system. Then download and install the software. Follow the instructions on the software. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Jun 24, 2010 | Lexmark JetPrinter X1185 All-In-One InkJet
I lost the cd for my printer hp deskjet f4180
You you can Download Full feature software and drivers from HP.com and even if you want you can order the Installation CD. I would have provided you with the direct link to download the software if I know the OS in your computer. Now Click here. Click on the Operating system you are using and a new web link document will open.
If you want to download software free of cost then : Click on the Fullf eature software and click on downlaodonly and save it on your Desktop.
If you want to Order the Installation CD then you will find the CD order link under the CD-ROM order page - CD/DVDs.
Hope the Information helps you to resolve the issue.
Dec 26, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hi: I've lost my cd for the canoscan D1250U2F...any suggestions?
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select the operating system (Windows XP/Vista,etc..) of your computer to download the appropriate drivers and software.
Hope this solves your problem. Thanks.
Dec 08, 2009 | Computers & Internet
Staples 2x1 USB Peripheral Switch Logo
413 people viewed this question
Top Staples Computers & Internet Experts
_-__-___-_
_-__-___-_
Tom Chichester
 steve
steve
Are you a Staples Computer and Internet Expert? Answer questions, earn points and help others
