Question about Garmin iQue 3600 GPS Receiver
Screen Display Problem
My iQue 3600 would not sync, so I did a soft reset.  When the unit came back on the screen lit up light gray with darker gray vertical lines.  Now, that is the only screen I get when I turn the unit on, and when I try to do a soft reset.  The light on the on/off switch is also not lighting up.  Any suggestions?
  • 2 more comments
  • DearDOC Nov 27, 2007
    Same problem
  • Timothy Ellis
    Timothy Ellis Dec 18, 2008
    Same problem with the gray screen and the dark lines. I began to take the unit apart to investigate, and noticed that the full screen functionality returned when loosening the lower-right screw (the one under the Que button). I suspect there is a cable to the screen under that corner that is somehow being pinched.
  • htbanks1 Dec 20, 2008
    I just bought a Garmin iQue 3600 from a friend, after one use of the unit, I got a gray screen with vertical lines. However, I only have the unit, car charger/cradle, usb station, and AC charger, is there anything I can do on my own, or am I better off calling tech support?
  • Colin Tombs Dec 31, 2008
    When i put my unit on the cradle to charge, the green light sometimes comes on, but not always. Mostly I have just a grey screen.Sometimes the screen comes to life, but sadly, only briefly.
    Novelist:
  • 233 Answers
Do hard reset? See Owners Manual.
Call Garmin they are very helpfull
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Posted on Nov 05, 2007
It says i have no connection between my handheld and my computer when i try to hot sync
If you are trying to HotSync to a Macintosh, you need to install Lycestra's PDiQue software available at http://www.lycestra.com/ique.html before HotSyncing is enabled. PDiQue enables a USB conduit between your Mac and the Garmin iQue 3600.
Oct 23, 2009 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 has a blink screen
if it will not power up, you don't have many options.
unscrew the head of the sylus to access the rest tool
Press the reset at the back with the stylus
This is re-booting, all data safe still here.
Hard reset is last resort...data erased here.
Press the reset button again as above
after you release, press the power button, keep pressing until the message
( all data stored is about to be erased )
to complete the reset press the upper half of the scroll button, on the front,
The digitizer screen appears
pressing any other button here performs a soft reset.
Update it if you get it up and running.
Hope this helps
Ric.
Mar 22, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
Ique 3600 Hard Reset problem.
Hold POWER button down while doing a RESET. On restarting all should be OK
Sep 12, 2008 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Broken screen
The best solution, in my opinion, is to buy a unit being sold for parts or repair (making sure that the LCD display was working) and do the replacement that way.
That's what I'm doing because when I write with my stylus it doesn't recognize what I write.
Dec 17, 2007 | Garmin iQue 3600 GPS Receiver
My ique 3600 does not respond
Try resetting the unit and calibrate the screen. The problem is that the screen is not calibrated.
Nov 30, 2007 | Garmin iQue 3600 GPS Receiver
Garmin Ique 3600
May be a hardware issue. I had similar behavior when I replaced my IQue 3600's battery. If the circuitboard inside wasn't seated properly on the contacts coming from the battery, the iQue would keep rebooting. Start by checking that all the external screws are snug (but not over-tight). If not, you can try to open the case to check the two screws inside holding the circuit board. But I'll leave that up to you, since I can't honestly guarantee that you're experiencing the same problem. (After all, you seem to be sure that it has something to do with the software...and you may be right.)
Feb 03, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
153 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
