Question about Samsung Washing Machines
How to I use the Pure Cycle on my Samsung washing machine?
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Posted on Jul 13, 2008
Samsung washer top load. Dirt in tub after wash cycle, have vacuumed, removed dirt, tried 3 more cycles, still sand like dirt or substance presenting after any ideas to fix
Try running wash cycle without laundry in machine but use washing machine cleaner instaed of washing powder. Normally sold in supermarkets for a few pounds.
Feb 01, 2018 | Samsung Washing Machines
Top load Samsung washer leaving like a moldy paste on my clothes
Use washer magic and your washers clean washer mode or pure cycle depending on model and maintain its cleanliness. Good luck.
Jun 10, 2017 | Samsung Washing Machines
Even in pure cycle setting we frequently get an E8 error. just now, it did it while filling with water for pure cycle. this machine is less than 4 years old and is costing me a fortune in repairs and costs...
An E8 code indicates a water cooldown issue. You might check to be sure the hot and cold water connections are not reversed
As for the clothing destruction issue, you might check back with test results for your machine when new. It could be a persistent problem.
Feb 26, 2015 | Samsung 4.0 cu.ft. VRT Top Load...
I just moved in a house with an old top loader washer After the water fills in and it starts to wash I get all these dirty particles What is that and how do I get rid of it
The dirty particles could be old soap dried in bottom. You could try putting white vinegar in soap dispenser and running on a pure cycle or if your does not have pure heavy cycle so it can break up the old soap. Unless you have well water and that can be caused by needing to add stuff to well for purifying the water.
Apr 20, 2014 | Washing Machines
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
Flashing light
If the cycle completes and your clothes are clean this is no issue. If the former does not happen. Then return to the store and get another machine.
Jan 24, 2014 | Samsung Washing Machines
Sandy residue
Are you on public water or a well? If you are on a well, you may need to replace the screen on the well point.
Jan 03, 2014 | Samsung Washing Machines
I have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
i have a samsung smart wash B1445V . the drum is not spinning /turning in the wash cycle as well as in the spin cycle..
Sep 21, 2010 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Washing Machines Logo
187 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
