Pound in a ton - Office Equipment & Supplies
1 kg is how many pounds
The answer to this question depends on the definition of the pound you are supposed to use. There are a number of different "pounds", the most customary are:
The British avoirdupois pound, where 1 kg = 2.205 lb,
the troy pound, where 1 kg = 2.679 lbt,
the metric pound, where 1 kg = 2.000 pound.
(all numbers rounded to three digits)
In the US, the avoirdupois pound was adopted in 1959, replacing a slightly lighter pound definition introduced in 1893. The troy pound is still custom in weighing gold and the metric pound is occasionally used in central Europe as an inofficial unit, e.g. Germany, Switzerland and Austria.
A wide variety of historic pound definitions exist; I am aware of at least 20 ranging from 1 pound = 1 kg (Dutch 'pond') to the 1 lbt = 0.37324 kg (troy pound).
Mar 13, 2014 | Office Equipment & Supplies
How many PSI freon dos this unit take to fill? S3QA-30KA 2.5 TON
unit's are usually charged in pounds not psi...units require a certain pound amount of freon to work properly....... it depends on the outside air temp, the inside air temp.... what type freon ?? need more details on unit and what type freon does it use??
May 10, 2011 | Heating & Cooling
What are the ramifications of pulling a 800lb wave runner..with my 98 cabrio
This car is not designed to tow any weight let alone a 800 pound wave runner on a trailer weighing even more. You will be towing over 1/2 ton. Possibly overheating the engine and transmission and you will have a hard time stopping unless the trailer has brakes. Not a good idea.
Apr 03, 2011 | 1998 Volkswagen Cabrio
How many pounds does the trillium tr-500 bread baker make? 1 or 1 1/2 lbs?
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Nov 27, 2010 | Breadman TR500 Bread Maker
I have a Toastmaster Automatic Breadmaker. Model 1196. I need to know if it is 1 pound or 2 pound breadmaker. THanks
Nov 25, 2010 | Kitchen Appliances - Others
Why is perfume so expensive?
Fragrances contain a certain amount of natural ingredients, which are expensive. To make a pound of rose oil, it takes well over a ton of flower petals, and this cost can range from three to four thousand dollars. The same is true for most essential oils.
Nov 23, 2010 | Health & Beauty
At a farmer's market you buy 6 3/10 pounds of red onions and 4 1/3 pounds of yellow onions.What is the total weight of the purchase?
If you don't have a calculator to help you with the division by 16, here is a list of all the decimals relating ounces to a pound:
  • 1 oz. = .0625 of a pound
  • 2 oz. = .125 of a pound
  • 3 oz. = .1875 of a pound
  • 4 oz. = .25 of a pound
  • 5 oz. = .3125 of a pound
  • 6 oz. = .375 of a pound
  • 7 oz. = .4375 of a pound
  • 8 oz. = .5 of a pound
  • 9 oz. = .5625 of a pound
  • 10 oz. = .625 of a pound
  • 11 oz. = .6875 of a pound
  • 12 oz. = .75 of a pound
  • 13 oz. = .8125 of a pound
  • 14 oz. = .875 of a pound
  • 15 oz. = .9375 of a pound
Jun 29, 2010 | Core Learning Fractions Step-By-Step...
Gurmit paid 21 pound for five presents, HOW MUCH
product a=2 pounds
product b=4 pounds
product c=6 pounds
product d=1pound
product e=8 pound
Mar 07, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Pound Key
Open a notepad and then press all the key on keypad and check which one is giving a pound key. This is required because if the key cover is changed in that case the pound will work when pressed a different key.
Also clean the keypad or else get a new one.
Thanks
Oct 31, 2008 | Toshiba EKT6520SD Phone
20 people viewed this question
jasbo
jasbo
