Question about HP DeskJet 5150 InkJet Printer
My HP deskjet 3520 is printing blank pages - HP DeskJet 5150 InkJet Printer
jaylex
  • 417 Answers
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Posted on Jan 28, 2008
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
  • 158 Answers
SOURCE: hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Posted on Feb 22, 2009
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
SOURCE: problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Posted on Apr 27, 2009
Clean printhead and breather hoses hp 3520
try to reset the the black printhead , and clean the it
Mar 23, 2013 | HP DeskJet 3520 InkJet Printer
How do ou update the driver on an hp deskjet 3520 printer?
Log on to HP.COM. Go to Support and download the driver for your printer. Go to your download folder and run the file you just downloaded.
Jul 02, 2012 | HP DeskJet 3520 InkJet Printer
Free download HP Deskjet 3520
Access the manufacturer's web-site: http://support.hp.com
and enter '3520' and do the search.
Select your Operating System.
Download the device-drivers.
Install.
Print a "test" page.
Feb 22, 2011 | Office Equipment & Supplies
Hp deskjet 3520 wont print. why?
update the driver or go to service centre
Aug 12, 2010 | HP DeskJet 3520 InkJet Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
Driver for HP Deskjet 3520
try to click at this link....use windows 2000
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=305968&lang=en&
May 26, 2009 | HP DeskJet 3520 InkJet Printer
On/off light keeps flashing green and will not print.
Your problem can be caused by a couple of things.....paper jam, printer cover open,etc...
But have no fear below is a link to figure out what is causing this problem and the solution to fix it....
Blinking Lights
Apr 27, 2009 | HP DeskJet 3520 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
