Ricoh quick service code 00-23 - Office Equipment & Supplies
2 Suggested Answers
  • 525 Answers
SOURCE: ricoh quick service code 00-83
No such error code on Ricoh AF1515
Posted on Jan 23, 2011
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
Dec 21, 2017 | Ricoh Office Equipment & Supplies
SP mode and SP Codes of Ricoh Aficio MP 2001L/2501L WITH ITS SERVICE MANUAL
Hi There,
if you want all the codes you have to download a service manual from the internet or get it from a Ricoh technician, is there a specific code you are looking for? the most common one is code 5 810 to reset error codes.
Jan 16, 2015 | Ricoh Office Equipment & Supplies
Sc 900 error code appear
Hi
You don't mention the make or model of your printer/copier, but a quick Google would indicate that it is a Ricoh machine.
I give below a link to a site which lists many models of many makes of printer and error codes. their description and cause, which will help you identify what is wiring and correct it:
Error Codes Ricoh Aficio SP4100N Code 900
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 30, 2014 | Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
I have a 863 code and my copier is fine tuned. Is the hard drive out or is there a quick fix?
Try to have the Hard drive reformatted first. This is done thru the control panel in the service mode
Jan 13, 2010 | Ricoh Office Equipment & Supplies
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh 3235
There are several resets to do in service mode.  One way to reset it quickly is to locate the lithium battery in the unit, remove it for a few seconds and then putting it back in.
That will reset everything.
Oct 23, 2008 | Office Equipment & Supplies
Ricoh 6513 streaking
Depending on your use IE lots of thick paper 150gsm plus.
The fuser rollers wear very quickly.
There is no Cheap fix for this.
These machines are very costley to run.
Ricoh Tech L3 22 years exp.
Mar 21, 2008 | Ricoh 6513 Copier
83 people viewed this question
k24674
jasbo
jasbo
