Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Grinder not grinding fine - Cuisinart Grind and Brew 10 Cup Coffee Maker
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
Coffee grinder is not grinding beans fine enough
Try it with less beans, or the motor is not running at full speed, no other fix
Mar 24, 2013 | Coffee Makers & Espresso Machines
It was working fine grinding coffee beam Ns when it just stopped grinding. I can not get it to grind again.
This model grinder has a 12 to 16 month life expectancy.. I would advise you to buy a different brand such as a Braun which last for years
Feb 13, 2011 | Cuisinart Grind Central DCG-12BC Blades...
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Rancilio grinder does not grind fine enough for espresso
After taking the top burr off several times and rescrewing it, I finally was able to exert enough force to get it to turn a couple of extra turns. Evidently there was some oil or coffee gunk (although I could see none) that snagged the bur. Now it appears to work as before.
This is a great, service by the way. Even the process of thinking through the problem so I could post it helped me solve it.
Nov 22, 2008 | Rancilio Rocky Espresso Coffee Grinder -...
Astra home electric grinder
Turn adjustment ring towards fine, until it cannot move, then back towards coarse about 5 numbers, that should give you a good start on the grind.
May 17, 2008 | Astra Home Grinder Electric
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
18 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
