Question about Magellan Triton 400 Handheld GPS Receiver
No uds manager for m400 - Magellan Triton 400 Handheld GPS Receiver
Test for s200 scanner says ud dll not found When i try to test the s200 compaq scanner on my system (windows vista os ) it gives a msg UD DLL not found. what can i do for that ??
You will need to reinstall drivers go to drivers in control panel device manager one of them should have yellow mark on it right click it and update drivers.
if this does not work right click and go to properties details and copy exactly what come up then do a search for it
Dec 11, 2016 | Compaq Computers & Internet
How to Load Vista or Win7 on a Toshiba Portege M400?
follow this steps
  1. You will find out that when booting your M400 from the Vista or Win 7 DVD, the setup program will not find your hard disk(s) The M400 has a SATA-RAID controller that doesn't have a "Vista Ready" driver! Use this driver
  2. Unzip the driver to a USB Memory stick and keep it ready for the disk management panel during setup
    • Use your Vista or Win7 DVD to boot
    • Stick the USB memory stick into any left hand USB port on your M400. you might have to try both ports until it is recognized by the setup
  3. Point to the memory stick when setup program ask you to load an external driver.
  4. Load the driver from USB Stick.
    • You should see the disk/partitions and should be ready to move forward in the installation process
Oct 20, 2016 | Computers & Internet
How to reset q mobile m400 to its factory setting
i need input phone password of q m400
Jan 12, 2014 | Cell Phones
Want driver for olivetti job-jet m400 windows 7
I can't find the job jet m400 on that list.
Nov 22, 2011 | Office Equipment & Supplies
Where sim card position in m400
Only a select few (very few) M400's have a 3G wireless module, and from what I understand they do not use a Sim Card as they use CDMA technology. You can tell if your unit has the 3G unit with several different ways.
A. Check the device Manager
B. Try and install the 3G power management driver, and see if it loads.
C. Check using Toshiba Utilities if installed
D. This is the hardest way, but the best. Remove the keyboard, and if the 3G unit is installed, it will be at the top right hand side of the case under plastic film. (I have had three M400's, including the top of the range one that I am writing this on, and I have never seen a 3G unit).
If you do have the 3G unit installed, look for an ESN number. You should then be able to then call Verizon and have the service activated.
G-Luck
Jan 08, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba M400 Battery 100% but when power disconnected shuts down
hi dear i dont think you can any test on this my addvice is take to toshiba service center ...
thnx
May 14, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Magellan Triton 400 Handheld GPS Receiver Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
