Won't power on.
I have a Philips 46pp912a/05 rear projection tv, it worked but not a great picture, I cleaned a lot of dust from the main circuit boards and now it no longer powers on, starts on 1 green light then goes to 2 green lights and 1 red one, after a while all 3 start flashing which doesn't stop, ps, this is a UK tv and I am a novice, although I can solder should it need new capacitors. Checked all connections are fine on the boards, the 3 coloured bulbs no longer light up, there is no service manual available to download from the philips website, and they have not answered my email regarding this...any suggestions? thanks.
  • paul Jun 03, 2014
    wow i only just seen this, again lol sorry for delay try herehttp://www.cqout.com/item/PHILIPS-46PP91...
  • 88 Answers
It may not be a fix but here goes,before this answer MAKE SURE THE POWER IS NOT ON, note where the switch is and follow the wire to main boaed, look for a plug on the end of the wire lift the plug and put it back on a couple of times also press the power seitch on and off do this a few times fast, hope this help's, paul.
Posted on Feb 14, 2014
Testimonial: "Hi, thanks for the suggestion Paul but no luck with that one."
  • 2 more comments
  • paul Feb 14, 2014
    sounds as if when you cleaned it you could have knoced a plug in the set, igoto flea-bay, oops rbay type in the mofrl followed by psu you may get lucky :)
  • bri watson
    bri watson Feb 14, 2014
    I've since had all the circuit boards out, given them a good clean, and reseated all connections, no signs of blown capacitors, but the largest circuit board below the front screen has signs of some connectors looking a bit black on the board, don't know what they are but they look like some kind of small cap (no ally on top), but not being a tv guy I don't know if they would affect power on? Can't find any help or parts anywhere, maybe it's just too old..like me :-(
  • bri watson
    Suspect??
  • bri watson
    bri watson Feb 21, 2014
    Well seems like nobody can help with this! I have now sourced a service manual for this set and have found a possible fix, just waiting for parts to arrive to try it.
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Posted on Jun 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
Does not power on
those usually have a series of soldered in fuses that have a 2.5 amp rating.. they should be near the power units for each one..
Jan 28, 2014 | Televison & Video
46pp912a/05
If thats a philips product it uses the star shaped screws that are torks.
Dec 15, 2012 | Televison & Video
Problem with the Philips Magnavox 9P6034C 60 in. Rear Projection Television, had TV for 16 years. Picture gradually got darker and less clairity
the projection tubes do wear out over time and there is no fix but to replace them. you might first check to make sure the lenses and mirror are clean, do not use compressed air to clean as you may force dust between the lenses. if the picture is darker at the edges or a different hue then the coolant is likely contaminated and needs changed
Dec 15, 2010 | Philips Magnavox 9P6034C 60" Rear...
Have a Hitachi 53sdx89BA Rear Projection TV. Turn on TV and red power light illuminates. No picture, but have sound. Check PC board in back and red led is flashing and green leds are lit. It was working...
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Feb 01, 2010 | Hitachi 53SDX89B 53" Rear Projection...
VS-5042 Sound but no picture
It is not bulb, are you talking about the tube ? At the neck of the tube you will see some connections.Carefully abserve if any cracks on the solderings(we call them DRY SOLDER), then connect them with soldering iron. Always make sure you have disconnected the TV from the mains. If the problem still persists, you will need to reffer to a qualified and Experienced person. He need to look for the LOT section(Auxiary power supply), video amplifier, CRT sections.
Aug 23, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Projection oil spill on main circuit board
The coolant in the CRT's is made up of 70% ethylene glycol and 30% glycerin. The coolant is highly conductive and somewhat corrosive. Since you already tried to turn it on im not sure but hopefully you wiped it up first. Take some 100% denatured alcohol and use that to clean the spill you can just pour it on and wipe it off with the set unplugged of course. then let the remainder on the board evaporate (It evaporates very quickly when open) and repeat the process. if your lucky and it did short the first time you turned it on the fuse just blew.
Jan 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips CRT Rear-Projection TV 64P8342
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Most common death mode)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Feb 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 60'' rear projection screen tv
That oil is glycol and is a coolant for the tube. Hope you didn't get the oil on the circuits because it is conductive and the tv will not operate with the oil on it. Must be completely full. Can be bought a electronic parts distributors or a tv shop could order you a bottle. Hope you just removed one tube only. Make sure you seal it back good
Dec 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
