Question about Cricut Expression Cutting Machine plus 2 Cartridges
Reset cricut expression 2
How to return to factory reset
When using a design in Cricut Craft Room, and select cut, my Expression 2 begins, but does not complete, the cut. The arm moves to the paper and then makes a croaking sound and then nothing.
Search cricut.com for support faq go to expression 2 search format and reset. Watch the video on format and reset and do as it says. Calibrate when it's finished. If this doesn't work re download ccr after deleting it from your computer.
Jan 10, 2016 | Provo Craft Cricut Expression 2 Electronic...
How can I get a new Encoder board V2Encoder for a Cricut Expression?
You may be able to get a replacement circuit board from the source where you purchased your Cricut Expression. More likely, It will require an inquiry to Provo Craft to determine availability and source.
Feb 02, 2015 | Provo Craft Cricut Expression Personal...
Cricut expressions 2 pressure wheel
You say you have a Cricut expression 2 but you say quote"...of how to reset the machine including the rolling of the dials up and down three times!" The problem I have in sorting your problem is that the Cricut expression 2 does not have wheels which work the speed, pressure and size. If you have an expression version 1 machine then there would be 3 wheels on it to adjust the speed pressure and size. Obviously if you have had the machine for 4 years it is out of warranty and I am not sure just what the person did to "fix" your problem. I do recollect a video on you tube with a similar problem however looking at the video he mentions that once it is fixed the blade housing should bounce up if you push it down, does your housing now do the same as the video. In the video Evan did he mentions at the end that the soldering of these wires may not take the first time so this may be a point to check as he mentions that it was travelling the machine that caused the wires to break in the first place. The youtube.com video I am speaking of is http://youtu.be/n7LJnfPdd08, by Evan Craftman. I am assuming that when you called cricut support you called the UK support line. I often speak with support in the USA being from New Zealand it is an overseas call however I have found them very good. If you are able to I would like to see a video of just what your machine is doing. If you dont want to post it here you could email me flohillrennie@gmail.com.
I do feel very sad that you don't wish to try the Explore as I find it a surpurb machine. I have had my Expression version 1 since early 2009, I have added every Cricut to my family of cricuts and own 3 expression 2's and now an explore. If you had bought a computer 4 years ago and you currently took it to a repair person to get it fixed I am sure their first response would be it would be better to get a new one. Your computer boards appear to be fine maybe you need to take the video to the person who did your fixing as most people who do this sort of work would not understand how the machine runs. I hope this helps and you can get your Cricut working again. If all else fails you may be able to buy a 2nd hand one cheep and have your repair person change the carriages completly.
Jun 13, 2014 | Cricut Expression Cutting Machine
Cricut expression 2
Cricket is hung up on the first small cut and keeps repeating that same cut over and over
Aug 09, 2012 | Toys
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
My cricut expression keeps turning on and off. Resetting does nothing since it won't stay off or on long enough to actually reset. Any ideas?
I would contact cricut because you may have a defective machine. I had an expression and cut one thing then it froze. We did the reset and that did not resolve the issue. Cricut had me send my machine back and they shipped a new one. Mind you they will put a charge on your credit card only to protect themselves. You just ship yours to them the way they tell you in the one you receive. Let me know if you do not have their contact number.
Feb 16, 2010 | Provo Craft Cricut Disney Font Cartridge
Dials not working
You may want to try resetting your Cricut to see if that fixes the problem. To reset the Cricut machine, turn the unit off for five minutes. Roll all the dials all the way up and all the way down five times each. Turn the Cricut back on. This is the manufacturer's reset process. Good luck!
Mar 13, 2009 | Provo Craft Cricut Disney Font Cartridge
Cricut Expression Cutting Machine plus 2 Cartridges Logo
326 people viewed this question
Top Cricut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Cricut Craft and Hobby Expert? Answer questions, earn points and help others
