Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Drink time vending machine keeps tripping breaker
Why are front three selections vending two cans?
There is an adjustment for the length of the cans. The columns that are not working properly have too much slack. Open it up and look behind the cans. There is a metal plate with spring loaded clips, top and bottom. Squeeze them together and move the plate forward to take out the slack. Do it top and bottom. When properly adjusted the cans will move a little (1/4 to 1/2 inch).
Apr 01, 2016 | Selectivend CB300 Satellite Ice Water Cold...
Tip
Vending Machine Supplier
About Us : <br>Upton vending A largest vending machines company in UK, that provides wide range of vending machines in North Yorkshire at affordable rates,well known for customer satisfaction.Our best services are <b><a href="http://www.uptonvending.co.uk">vending machine companies</a></b>,vending machine, snack vending machine, drink vending machine,commercial coffee machines in UK..<br>Contact Us : <br>The Vivars<br>Selby<br>North Yorkshire<br>YO8 8BE<br>Tel: 0 1757 629112<br>Fax: 01757 294600
on Aug 17, 2013 | Nu-Dell Manufacturing Vending Machines Ad...
I have a Mercato 2000 Snack Vending with Summit 300 Satellite Drink Machine. The coins do not deposit into the dispensers. It collects at the top. How do i get it to drop into the dispensers?
you may have a coin jammed in the coin reader device. I know absolutely nothing about your machine but am a gaming attendent and have the same type of fault occuring on gaming machines from time to time. Foreign coins or bent coins also can jam up the reader.
check if the coin reader can open up to release coins.
Jun 17, 2015 | Retail Supplies
Genesis go380
how come my Genesis will dispense two chocolate bars at a time? Is this a setting of some sort?
Aug 13, 2013 | Selectivend Combo Vending Machine for 14...
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
Need ac adapter for drink o matic
I used the car adapter cable that came with it, and bought a Sunforce AC/DC Power converter (Model: JT-DC12V5.8A) for $20.
You can find these all over the place.
Jun 08, 2010 | Sharper Image Drink-O-Matic
Hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Aug 26, 2009 | Hotpoint Washing Machines
Buying parts
I believe its the same one as the Wii AC adapter
Dec 18, 2008 | Sharper Image Drink-O-Matic
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
21 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
