I need to unlock my cell phone so I can get service through my curent provider.It use to be hooked up to inland cellular and I want to hook it up to my at&t provider. Can you please help me? Thank you!
My canon S9000 uses my MAC OSX 10.5.8
Since I cleared a paper jam, and as far as I can see...
(More)
Since I cleared a paper jam, and as far as I can see partially disassembling unit there is nothing left in there, nonetheless the unit powers up OK but when I click on print the paper passes through and then I get three short yellow flashes and a green one. I get error code 306 communication error.
Thanks
Greg
I am trying to scan multi page documents into one document so i don't have to attach each page when...
(More)
I am trying to scan multi page documents into one document so i don't have to attach each page when i send an e-mail, or print one page at a time. I just spend 40 minutes on the phone listening to drones tell me they couldn't service the problem as they haven't been trained on the model yet. It's the MFC-255cw. When I asked them to explain the process on a machine they were trained on, they REFUSED! Help!
check to see if the fuser is working yu should be able to tell if you open the side door up at the...
(More)
check to see if the fuser is working yu should be able to tell if you open the side door up at the top you will see the fuser orange roller and black.. feel to see of it has gotten hot be careful though it does get upto 180c.. if this is ok then check the toner is set right as it may be trying to load did you give the toner cartridge a shake before you put it in this can sometimes be compacted.. good luck A
