Question about Konica Minolta DiALTA Di200 Copier
Reset password minolta di2510 - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 6,161 Answers
Which one admin or service
Posted on Jan 18, 2016
5 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: Minolta Di2510 Copier
SOUND LIKE TRAY PROB.DO YOU HAVE LCC ?
CHECK ALL TRAY
Posted on Oct 06, 2008
  • 11 Answers
SOURCE: Kinoca Minolta Di2510 Double-sided printing
Yes it can be done, if the m/c is having duplex unit.
Posted on Aug 17, 2009
  • 170 Answers
SOURCE: Konica Minolta Di2510 error code C0500,can not
check the fusing unit parts heaterlamp,thermistor & thermoswitch i'm sure one of them is the cause of error c0500
Posted on Nov 22, 2010
saxmansaxman
  • 177 Answers
SOURCE: I have Konica Minolta DI2510
You can try to reset the C0500 error code press the soft initialization on the right side of control panel when the dot appears on the lcd after reboot press the number 3 key the mode will change to the initialization screen choose the selection for trouble reset after reboot the code will be cleared power on and of for basic screen if this dose not work you will need to replace the fuser unit
in regards to your c0f32 code the toner to carrier ratio is wrong this is caused by the wrong developer being used clean out developer unit and put correct developer in the unit
Posted on Feb 01, 2011
My konica minolta di2510 is showing co500. i figured out it is from the power board and i have checked fuses and they are ok. so what could be the problem of the power board
did u checked with other Fusing Unit on same machine with same power supply board. c500 due to Fuser heating error.
are u able to reset first?
Dec 03, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
I want to clear cof32 in my DI2510 minolta
replace the drum and developer clear counters first then run F8 afterward
Sep 08, 2016 | Minolta Di2510 All-In-One Laser Printer
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Di2510 admin password
Default password admin is 00000000 or12345678 unless changed by previous owner? Can be reset in service mode
Feb 13, 2014 | Minolta DI2510 Black and White Copier
Minolta DI2510 Black and White Copier - Code reset minolta issues?
what code do you want to reset different code different reset procedures
Nov 22, 2011 | Minolta DI2510 Black and White Copier
Problem "don`t boot up" in
Check the power supplies. check power cord plugged in properly to the machine snug and tight recommend a tech from Konica Minolta
Apr 16, 2011 | Minolta Di2510 All-In-One Laser Printer
I replaced the drum unit to my Minolta DI2510 copier; but the message to replace the drum unit has not gone away. How do i reset the message?
You can not just reset the drum counter. When you reset the counter then the ATDC reference value is also reset. This will throw off the developer to toner ratio and your copies will usually become light or overtoned. The developer is supposed to be replaced at the same time the drum is replaced. The drum count is then reset and the F8 function in the service mode is run to calibrate the new developer. If you do not perform this procedure in the right order and correctly you will end up with at best poor copy quality. I would recommend calling a service person out to change the developer and then reset the counter and do the F8 procedure.
Good Luck and Thank You for using Fixya.
Feb 02, 2011 | Minolta Di2510 All-In-One Laser Printer
Mar 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
