I have a celcus cwm 1005 lights keep flashing and nothing happens on any cycle
Sometimes it will spin or even wash but it's a bit hit and miss
3 Suggested Answers
  • 6277 Answers
SOURCE: i need a manuel for
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 23, 2011
  • 6277 Answers
SOURCE: I am trying to get
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
John C.
Posted on Sep 01, 2011
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
I am trying to get hold of a manual for a celcus cwm 1005 washing machine, can you help?
Manual
John C.
Sep 01, 2011 | Washing Machines
I need a manuel for a celcus cwm 1005 washing machine
John C.
Apr 23, 2011 | Washing Machines
Spin cycle is hit and miss,
It could be the timer but don't rule out a loose lid switch. You have to remove the knob to get the timer off. To do so you have to pull the retaining rod out a bitdd8bcfd.jpg
To get inside the controls
Apr 19, 2010 | Whirlpool Inglis IP4400 Washer
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
