Question about Sony CCD-TRV238E Camcorder
I GET A BLUE SCREEN IN PLAYBACK MODE NO IMAGE AND NO SOUND
SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Posted on Aug 02, 2007
  • 4234 Answers
SOURCE: Camera mode video not working
This could be as simple as the iris stuck closed or more expensive (ccd defective). Without taking the camera apart, it will be difficult to say with any confidence. Have you looked around to see what a repair estimate will cost? Perhaps you can get a detailed estimate from a local shop. We may be able to walk you through the repair?
Dan
Posted on Jun 12, 2008
quang123
  • 107 Answers
SOURCE: No playback
It could be video head partial damaged or got dusty, another possibility the tape guide alignment was out of position. If the video defective it require to replace1 drum assembly it come the video head and motor it is not worth to repair and you need a qualifier Tech after replace it they need to connect computer to do alignment mechanism and electronics
If the head is dusty you could try insert the H8 tape cleaning should buy from Sony may be you can clean the video head the change is 30% success
I hope that give you some ideas
Posted on Dec 04, 2008
  • 18 Answers
SOURCE: Sony CCD-TRV65 No Display on Playback-blue screen
i Had exactly th esame problem with mine and i sent it back to sony as i read it was a chip fault and they repaired it free of charge for me and sent it back very promt. Contact them via email and check out similar problems online they detail the exact cause of this and it helped my case enormously.. i hope this hlps you bu ti did read they had a time limit on this fault so good luck.
Posted on Jul 21, 2009
SOURCE: Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Posted on Jan 26, 2010
How to make a digital copy
o do this:
Press the power switch. (Capture mode)
Press the Play button. (Playback mode)
Press the four-way controller (down). (Playback mode palette)
Press the four-way controller (right) 3 times to select [Image/Sound Copy].
Press the OK button to display the screen for selecting the copy destination.
Press the OK button to copy the data.
Press the Play button or press the shutter release button down halfway to return to Capture mode.
Playback Mode Palette Copy destination selection
* This function can only be selected when an SD (SDHC) Memory Card has been inserted in the camera.
Jun 11, 2012 | Sylvania Hd1z Sdsdhcmmc 720p Hd Pocket...
Hi, my husband bought a fuji a330 from a friend and it seems to be stuck in playback mode (blue screen that says no image). I can't figure out how to switch back to camera mode. Can anyone out there tell...
You need to open the frontcover fully untill it clicks, and, if still in playback mode, to press the shutterbutton half way down.
If you hold down the playback button for 2 seconds, even while the lenscover is closed, the camera will go into playback mode.
May 03, 2010 | Fuji FinePix A330 Digital Camera
Nikon D90 Image playback Mode
Hi - My D80 allows the length of time the the image displays to be set using the menu system. You shouldn't have any trouble setting this. Mine can be set from 5 sec to 10 minutes. Lookup Monitor-Off in your manual.
Apr 27, 2009 | Nikon D90 Digital Camera with 18-105mm...
Jvc gr-dx28ek black screen during recording
if u can see the old videos in playback mode those videos when ur camera was ok then it is
BAD CCD !
see the link for free repairs from JVC dont worry if u are out of warranty and not on list just call them PLS RATE ME FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Apr 14, 2009 | JVC GR-DX28E Mini DV Digital Camcorder
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
No image message
It sounds like you are in playback mode with no images on the memory card. There is a dial on the top of the camera that selects cameras mode or playback. The manual is available for download here:
www.ultramod.com/sringar/chemtrails/S5000Manual.pdf
If you like this solution, be sure to rate it! Thanks!
Nov 08, 2008 | Fuji FinePix S5000 Digital Camera
No playback
Oct 21, 2008 | Sony Handycam CCD-TRV308 Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Sony CCD-TRV238E Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
