Question about Gateway M275 Tablet PC
Gateway tablet screen won't rotate - Gateway M275 Tablet PC
How do i rotate screen on my tablet?
You should be able to just turn the tablet on its side an the screen would auto rotate but if not go to settings an select screen settings/display an change the setting to auto rotate.
Aug 13, 2014 | Tablets & eReaders
Acer how to setup
You are looking for an option called Rotation or Rotation Lock (varies by Android version and tablet). Once you find it, orient the tablet so it is in landscape mode, then turn off rotation. If you do not have an option on the bar at the top of the tablet (top pull-down you get by sliding down a finger from the top of the screen), then go to Settings, Display, and look for Rotation, Rotation Lock, or Screen Rotation.
Jul 17, 2014 | Acer Iconia A1-810-L888 7.9 inch MediaTek...
The screen has probably cracked. Screens are replaceable, but I wouldn't suggest trying to do it yourself. Get it done in a shop. Gateway will tell you how much it will cost.
Mar 20, 2014 | Tablets & eReaders
My zeki tablet wont rotate when you turn it
go to setting>display>rotate screen
check the box(click in box)
it'll activate auto rotate
Jan 29, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
Screen will not rotate
Some tablets will have a physical rotate lock switch. There is also a setting that locks the rotation. Settings > Display. Auto Screen Rotate.
Dec 08, 2013 | Samsung Galaxy Tab Tablet PC
My tablet screen won't rotate
Make sure you have enabled screen-rotation in your tablet settings.
Nov 17, 2013 | ASUS MeMO Pad HD 7
Screen won't rotate
Please press Ctrl + Alt + Up Arrow keys to rotate the screen. This feature is completely depending on the Video card installed in the Computer.
Jun 30, 2010 | Gateway CX200X Tablet PC
I am having a problem with a broken screen on my tablet gateway notebook the screen broke can it be replaced
you can replace the glass by taking it too the nearest glass store as long as the screen still works
Dec 02, 2009 | Gateway M275 Tablet PC
I cannot rotate the screen's display using the tablet control button
Try holding down the CTRL, ALT and the up arrow or any of the arrows and see if that does the trick with rotating the screen.
As far as the normal rotate button is concerned, try downloading the drivers for it thru toshibas website. If you have the model number of your laptop I can help you with that.
May 21, 2009 | Gateway Tablets & eReaders
Screen going nuts
The connector is damaged. The connector was meant to only rotate 180 degrees and only in one direction. You are partially correct. The wires are twisted. Probably beyond repair. You could open up the laptop and the screen and look at the wiring and the connectors and see if they have just been dislodged from the connectors. Typically they are sliding connectors with film type wiring. You pull out on the connector to release the film. Otherwise, you are in for a rude repair bill.
Jun 18, 2008 | Gateway M275 Tablet PC
Gateway M275 Tablet PC Logo
14 people viewed this question
Top Gateway Tablets & eReaders Experts
Daniel Florin
Daniel Florin
ashburton
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
