Question about Maytag MEDX700XL Dryer
After reversing door light what's on
Door has been reversed Shuts and seals well but light stays on and unit will not run The switch is now located on the hing side There is a small pocket (1/2" x 1/2"" wide , 1/16" deep ) on the door which aligns with the switch If I jam a piece of cardboard between door & switch the unit works
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: reversing door
you can not change the way the door opens
Posted on Feb 11, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: what does the reversal kit consist of
As far as I know there isn't any "kit" needed to switch a door. It's just a matter of taking out a bunch of screws, reversing some door parts, and putting it all back together. Here's a link that shows how to do it for one model which is typical:
http://www.maytag.co.uk/Assets/U&C_MDE3706AGW.pdf
About all you need is a phillips-head driver and maybe a small putty knife to pry out the filler plugs from the holes you'll be using.
Posted on Feb 21, 2009
  • 3074 Answers
SOURCE: reversing dryer door on Maytag
on the opposite side there are two plastic fillers, take out, take the screws of the hinges, lift out an up, screw hinges into where fillers where, screw fillers into where hinges where. Hope this helped Tim
Posted on May 08, 2011
mc1bean
  • 3053 Answers
SOURCE: The dryer shows door open
Hello, jmI was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Why is my garage door suddenly reversing when going down?
Deb, that reversal is a child safety device - if the bottom edge of the door detects contact with any object, it'll immediately reverse so it doesn't kill a child. Or a cat, dog, whatever.
The opener mechanism should have a stop switch that prevents the door from closing hard against the floor - that stop switch needs to be adjusted so that the door will stop JUST before hard contact. That'll take care of it "bouncing" off the floor & reversing. As to it reversing before it touches the floor... examine both guide rails closely to see if there's any obstruction that the door's bottom edge may be contacting to trigger the child protection reversal switch.
Aug 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Tip
How to safety check your garage door opener
Place a 2x4 (or other object that is solid and about 2" thick)flat on the ground in the middle of the door. Activate the opener and lower the door until it makes contact with the 2x4. It should hit the 2x4 and then reverse in the upward direction. It can put pressure on the 2x4 just not stay there. If it reverses then it has passed. If it stays down then find the down force adjustment on the opener and turn it down. This adjustment can be found in your manual and will differ in location from brand to brand of garage door opener. Check the belt/chain for slack when it is running(there is no need to check this on a worm drive opener). If there is more than 3/4" slack then tighten it up with the tension adjuster on the trolley. Check the force adjustments per the manual as well. Do not pay attention to this slack when the door is shut as the trolley arm presses on the opener arm to gain the best seal at the bottom of the door. If you have a screw drive you can lubricate the screw with liquid graphite. All other types need none unless you want to lubricate the nylon gear inside the unit with rail grease, but be careful here and unplug the unit first. If your garage door opener has safety eyes start the door down and then cross the beam. The opener should reverse upward. If it does it passes, if not then call a reputable repair firm. Thanks BB
on Sep 03, 2010 | liftmaster Chamberlain Garage Door Opener...
My gas dryer Kenmore 500 series won't start when I push the start button. The light is on in the dryer chamber. The door latches and there is gas running in it.
the one side of the door switch is bad,one side controls the light when the door is open,the other side of this switch makes the unit run when the door is closed,replace the switch,or if you dont care about the door light,reverse the 2 larger connections and it will work again,but no light with door open then
Feb 11, 2011 | Kenmore 500 7953 Dryer
I am having the same problem the garage door won't stay down. I have leveled the sensors light beams and make sure that nothing was in the path. I have the model where the light is on front end toward...
The lights sensors are not the problem.
Garage door will reverse direction automatically if it contacts the hood of your car or a bicycle. Your garage door is coming too far down, impacting the concrete, and then reversing.
The fix is simple.
You need to adjust the tripper switch just above the garage door. When the door is closing, it trips a little lever that's attached to the center rail. It's just a little flipper with 2 wires connected to it.
Move this flipper switch back tower the closer mechanism about 3 inches >>> try garage door again >> and then adjust location of flipper until garage door works just right.
Oct 10, 2010 | Electrical Supplies
On operating my remote the garage door opens but when l try to shut the door it shuts then opens straight away the only way l can stop it is to press the remote again .There is a green light that keeps...
It sounds like the door is traveling too far, hitting the floor and then reversing to the open position. If this is the case you need to locate the 'down limit' control on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
It is normal for that small green light to flash randomly. It can also assist in diagnosing some problems by flashing a code. It will flash a number of times and then pause and then repeat. If this is the case, post the number of flashes.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't stay closed. One sensor light is green, the other side is yellow. What can I do?
The sensor colors are normal. If the main light is flashing 10 times when the door reverses it is a sensor problem. Make sure the small light on each one is not flickering ever so slightly. Tweak them a bit to make sure. If the door is reversing when it hits the floor you need to adjust the 'down limit' control on the side of the motor unit. Turn the control in the opposite direction of the arrow printed on the cover. You might also increase the 'down force' control which is on the rear of the motor unit.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
When i press the control the door goes down about a foot and then comes back up and shuts off.I checked for obstructions on the sensors and did not find anything wrong
If the main lights flash 10 times when the door reverses it is a door sensor problem. Make sure they are aligned and that the small light on each of them is lit and not flickering. If you can't get both lights to come on you most likely have a sensor that has failed.
If the main lights do not flash when the door reverses you most likely have a bad RPM sensor board. This is a small printed circuit board just in front of the motor and is what causes the door to reverse when it hits an obstacle.
You can also try increasing the down force adjustment which is on the rear of the motor unit near where all those white wires go. This will affect the safety reversing of the door so don't turn it too far.
Nov 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens after closing
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Maytag MEDX700XL Dryer Logo
22 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
