Question about Samsung Refrigerators
What connection kit for samsung RF22 icemaker
My Samsung freezer is making a loud knocking noise every 40 minutes in the ice maker area.What do you think?
Is your water connected? If not then turn icemaker off so the water valve will not energize for water supply to icemaker. Otherwise it could be the refrigerant lines knocking when compressor comes on. No real fix for that unless you want to check the sealed system pressures
Feb 25, 2015 | Samsung Refrigerators
Hook up icemaker to water source
If you are doing a new installation, the icemaker should either come with an installation kit or recommend one. The kit comes with all of the hardware needed to basically "tap" into your existing cold water line. Your refrigerator is already prepped for the icemaker so it's just a simple bolt in operation.
Jul 28, 2014 | KitchenAid Refrigerators
Frigidaire refridgerator leaking in icemaker
Try buying a new ice maker kit and replace it by doing it yourself. This would help you in saving money.
I recently bought a ice maker kit at lower price from Partsimple.com. they delivered it faster compare to others available in market and that too at low cost. Isn't that Good?
Try searching with compatible model no on Partsimple website.
Feb 11, 2013 | Frigidaire Refrigerators
Is there a ice maker avaiable for a GE TBX211A The Refrigerator was Made 10/19/98
Hello.
Yes their is a icemake r kit that will fit in your ref.
its part number IM6 and contains the icemaker,ice storage bucket,water inlet valve and all the necessary tubing and wiring for it...what is not included would be a water supply line that connects from the house plumbing to the icemaker
Its available from Lowe's,HomeDepot, or online many places (google IM6)
GENE
Sep 08, 2011 | GE (GTS16BCS) Top Freezer Refrigerator
How to install a Samsung RFG237ACRS refrigerator ?
Go to http://www.comparance.com/Refrigerator/Samsung/RFG237ACRS Download the installation guide. Unless you are fitting into a cabinet then these units just sit there. The front legs can be adjusted to level and thats it unless you have ice and water to connect. This takes a small water hose that can usually be purchased or may come with the unit. These are usually part of an icemaker setup kit.
Jul 21, 2011 | Samsung Refrigerators
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
