Question about Konica Minolta Di200 Di200f Di250 Di250f Di251 Drum Kit
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
  • Konica Minolta Master
  • 6,161 Answers
Print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Jan 18, 2016
Error code c1800
Did you mean C1300 no such number 1800 in the service manual. If so that code means something wrong with Print Head the Assy. that has the LASER in it along with the polygon motor. Power off to reset. Mite also be the image control board. so check connections between the print head and the image control board.
Jan 20, 2014 | Minolta - DI200F Printer
C1300 error code Minolta Di250F
Print Head failure. The print head is what has the copier LASER inside of it. Check the connection between the print head and Master board. Replace the print head fist then board, if you can find either one. The Di250F is a legacy Minolta machine now konicaminolta.
Jan 07, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Code c1300
That is the code for the print head. The Print Head has the LASER and a very high speed motor called a polygon motor that spins around 35,000 rpm. If power off then on does not fix it replace the Print head Have a tech make the ribbon cables from the print head to the main board are good connections. Main Board could also be bad.
Dec 04, 2013 | Minolta - DI200F Printer
Error code c1300
Print Head or Master board. print head houses the printer LASER. Check connection between both above then go with print head then with master board, worse case.
Apr 08, 2013 | Minolta - DI200F Printer
Error code c1300
Print head failure the print head houses the LASER. Chk the connection between print head control board. replace print head first if then not that control board. CHECK all connections on the control board first also bent PIN! pull each connector one at time
Apr 05, 2013 | Minolta Office Equipment & Supplies
C1300 code on dialta Di251
print head failure. print head houses the LASER. Check the connection between the LASER (Print head and the control board. CHECK FOR BENT PIN
Nov 12, 2012 | Minolta Office Equipment & Supplies
C1300 code on minolta Di151
Print head failure which houses the LASER. dry to see if the web site below has it.
Feb 06, 2012 | Minolta Office Equipment & Supplies
Could i get the unlock code (restriction code) for my LG C1300
Yes, you can get LG C1300 unlock code from your network provider. Just call them and pay some charge from your provider then LG unlock code will be delivered in a couple weeks. If you so urgent need that code you can buy from third party sites.
Jul 31, 2011 | LG C1300/L1200/4010/4050/L1150/G4015...
Code c1300
C1300 Code polygon motor inside the print head the LASER that places the image on the drum then paper. Turn off then on if it comes back replace the printhead. expensive sorry!
Mar 02, 2010 | Minolta Office Equipment & Supplies
Di181 Code C1300 What does this mean? How do I
The PRINT HEAD has failed that is the LASER UNIT in the machine, need a new one
Aug 03, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta Di200 Di200f Di250 Di250f Di251 Drum Kit Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
