Question about New Home HF-2022
Hf2022 bobbin loading instruction
No manual and need to fill bobbin
2 Suggested Answers
SOURCE: Bobbing Winding
i have and love this machine...pull out the large side knob on the right side of machine and switch the bobbin to the right side on the metal winder at the top.you will hear a little pop on those 2 steps...put a thread thru the hole in your bobbin and give your foot pedal some pressure....really easy
sonyainkaty@sbcglobal.net
Posted on Aug 06, 2008
How to fill bobbin
All machines are different, but basically it is done on the top of the machine. First you disengage the drive to the needle by slackening off the wheel in the centre of the manual drive (the big knob on the end of the machine for manually moving the needle). The bobbin and the threads spool go on spigots on top of the machine with the thread threaded past a roller. You put the thread into the bobbin and operate the foot pedal and the bobbin fills.
Most of the instruction manuals are online.
Google
make model manual
Dec 04, 2016 | Sewing Machines
How to fill a bobbin on this machine. No manual
I have heard there are some machines that have hidden bobbin winders that pop up when needed but have never seen one personally google make ,model and manual see if you find one you can download
Mar 16, 2015 | Singer Sewing Machines
Janome model us 2022
here are 3 links for a janome 2022 for any other part you'll have to contact a janome dealer or check ebay
Janome 2022 Parts Janome DX2022 Parts Janome HF2022 Parts
May 01, 2014 | New Home Sewing Machines
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
Manual
I found the manual you are looking for here:
Newhome Instruction / Owners Manuals
Dec 16, 2008 | New Home HF-2022
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
Singer Futura 900
Here is a FREE manual for the Singer Futura 900
http://www.singerco.com/uploads/download/a519b77b90074797a4f001327810f68ccb64f3d1.pdf
Mar 11, 2008 | Sewing Machines
Bobbing Winding
Jun 02, 2007 | New Home HF-2022
New Home HF-2022 Logo
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
