Video controller failed to initialize or respond.
The controllers does not work, and has to be reconnected. it works only for some seconds and then asked to be reoconnected again. The second controller does not respond at all. Batteries are new and...
It sounds like it connects initially, then disconnects? And you said the batteries are new. Are you sitting close enough to the console? If so, then you probably have a bad controller. Borrow a controller from a friend and see if they work. If so, then you know it's your controllers. Otherwise there is something wrong with your xbox.
Aug 30, 2010 | Microsoft Xbox 360 Console
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
ATI Rage mobility graphics card update for dualview
Display Driver
http://ati.amd.com/support/drivers/xp/radeonxprevious-xp.html 13.3MB 8.12 12/10/2008 Display Driver Only tooltip.gif try this you might need new update to receive dual view
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows XP. These include:
• Using an HDMI cable to connect an ATI All-in-Wonder to a Yamaha receiver
may result in the display resolution being limited to 1280x1024 and audio
failing to function
• Catalyst Control Center, some of the 3D settings are not displayed on ATI
Radeon HD 4870 adapters
• The operating system may fail to start after installing the display driver with
some configurations of "Crosfire" with Radeon X1900 Series devices
• The operating system may intermittently fail when exiting Test Drive Unlimited
after extensive game play
• Dual display, playing multiple video files on each monitor may cause the system
to stop responding
• City of Villains: Attempting to launch the game on a system running Windows
XP and containing either two ATI Radeon HD 38x0 or 46x0 products
may result in the game failing to load and the operating system failing to
respond
• Some OpenGL applications may cause the OS to stop responding on some
ATI Radeon HD 45xx adapters
• On some configurations, the display driver may stop responding when resolution
is set to 2048x1536 with 8X Anti-Alias and Edge Detect filter enabled
• Exiting some games may intermittently cause the following error message
when 8X anti-alias edge detection is enabled: "Display Driver stopped working"
• Hot unplugging a HDMI connection during video playback may cause system
instability
• Catalyst Control Center: Enabling pulldown setting may not work on all video
formats
• Systems configured with Overlay Theater Mode enabled may intermittently
become unresponsive after playing video
• Catalyst Control Center, setting the de-noise slider does not affect the quality
of progressive video content
• Intermittent flickering may be noticed on the TV out display when playing a
DVD using Cyberlink PowerDVD
Jan 22, 2009 | ATI RADEON HD 2400 PRO Graphic Card
HP PSC 1510 All-In-One-Printer not responding
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
I'm am trying to play age of mythology and after the movie ends, error appears and states "initialization failed".
Initialization failed
This means that the game is attempting to initialize hardware such as the video card but has failed
This can be caused by a number of factors.
1. Your hardware does not meet the games hardware requirements
2. Your hardware requires farther configuration to run the game properly
if you are certan that the game supports your hardware you may need to perform
some extra steps to get your game working
"Failed to initialize" is an incomplete error message because it does not tell you what exactly failed
a more complete error message would read "Failed to initialize the video subsystem" and then it would give an error code such as Error Code xxx telling you exactly what error code to look up
to determine what exactly failed.
Most of the time when a game says ( failed to initialize ) that means a video issue
this may mean missing files or wrong versions of files or incompatable hardware.
Selah.
Sep 15, 2008 | Computers & Internet
Door locks dont operate with remote key fob
Touch Key metal to lock cylinder metal then unlock
Jul 29, 2008 | 2001 BMW 325
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Won't respond to remote
Access servicer menu,run initial set-up. Have you already tried hard re-set? Leave it unplugged from AC overnight==== Also,please verify model #
Oct 05, 2007 | Sony KV-36FS100 36" TV
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
