Question about Bosch WFMC 3200 Front Load Washer
Bosch vision 300 series e12 error code - Bosch WFMC 3200 Front Load Washer
  • 5 Answers
SOURCE: bosch 300 series washer// led code E04
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Posted on Mar 02, 2009
  • 10 Answers
SOURCE: My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Posted on Nov 27, 2009
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
richroth
  • 9472 Answers
SOURCE: Have a BOSCH 300/500 series washing machine.
The door locking mechanism has malfunctioned and/or is overheating. It is recommended that remove power from the appliance (unplug it) for 30 minutes and try again. If the problem persist, you will need to replace the door lock assembly.
Posted on Nov 26, 2010
  • 39 Answers
SOURCE: Bosch vision 300 gas dryer shows error E12 evry
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Posted on Jan 19, 2011
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
How to clear error code e27 on bosch vision 300 washer
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
5. I set the knob back to off, and the washer now appears to be operating.
6. You're done.
Feb 08, 2016 | Bosch Vision 300 Series 3.3 cu. ft....
My Bosch Vision 300/500 DLX series washer machine washer stopped in mid cycle, with error code 13. What to do
The code means that the water is taking to long to pump out
unsrew the pump filter at the bottom front right
have some towel ready to soak up the water
clean and replace filter
most times this fixes the fault
if it doesn't then check for a blocked drain hose or faulty pressure switch
Jul 22, 2015 | Bosch Washing Machines
I have a Bosch 300 vision washer which wont turn on. The lights are on and there is no error code showing does anyone know what might be wrong?
lights are on, but won't turn on? I don't understand. if it simply won't start turning after filling, this could be the motor brushes. if it isn't starting at all, you may have an issue with the door mechanism.
Dec 08, 2014 | Bosch Vision 300 Series WFVC3300UC
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
Bosch vision 300/500 dlx series washing machine: how do you remove the front kick plate to access the pump?
Bosch vision 300/500 dlx series This video will show you how to change the pump washing machine Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 08, 2012 | Bosch Washing Machines
Washer is showing E12 error. Help
Hello.
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
Aug 02, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
Jan 17, 2011 | Bosch Dryers
Bosch WFMC 3200 Front Load Washer Logo
563 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
