Question about Humminbird 798ci SI Combo GPS Receiver
On off button will turn on not off and left scroll will not work
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
How do I rest the Service indicator for a 2005 CLK Cabriolet? None of the suggestions listed below worked for me.
First make sure all of the doors, hood, trunk, etc are closed.
Turn the key to position 1
Press system select button(lower left buttons on the steering wheel) that looks like sheets of paper until you see mileage reading or temperature displayed.
Press the brightness button on the lower left instrument cluster 3 times. You should hear a signal and see voltage on the display.
Turn the key to position 2
Press the lower scroll forward/back button(steering left arrows)). You should see "service indicator" on the screen
Press the Brightness button again once. You should see oil type on the screen.
Select the oil grade you used by pressing the + & - buttons on the upper right on the steering wheel.
Press the scroll forward/backward button to confirm. Confirm oil reset, press R(brightness button on lower left on cluster) for 3 seconds should appear on the display.
Service confirmed should appear on the display.
Press the upper forward/backward button & "service indicator" appears on the display.
Press the upper system select button(lower left steering wheel button on left) The display should go back to basic mileage or temperature.
If all else fails. I believe the shortcut I took as a tech was, turn the key to the first position, scroll until you see the temperature or mileage displayed. Turn the key off, push in the brightness button and HOLD it while turning the key to the 2nd position. You should see something like do you want to reset service? press R(brightness) button for 3 seconds and it should reset.
Good luck. The newer cars are worse.
Oct 10, 2013 | Mercedes-Benz CLK Cars & Trucks
Service light reset on nissan nv200 van 2010
With Doors closed turn ignition on. Using left button on speed press multiple times until it says settings, twist left button to scroll on detail then press left button. Scroll onto maintenance and press left button, then scroll on to service, hold in left button and the scroll onto reset, press button once and scroll onto confirm and press for the final time. Light is now reset and scroll back to exit.
Apr 14, 2011 | Nissan NV2500 Cars & Trucks
How do I change the language back to english
Please Follow this steps..
Turn on the printer
  1. From the operator panel, use the left and right arrow buttons to scroll to SETUP, and then press the select button.
  2. Use the left and right arrow < > buttons to scroll to Defaults, and then press the select button.
  3. Use the left and right arrow < > buttons to scroll to set Defaults, and then press the select button.
  4. Use the left and right arrow < > buttons to scroll to use Factory, and then press the select button.
  5. Select the correct language and country.
Good Luck! :)
Feb 03, 2011 | Dell V305 All-In-One InkJet Printer
Install the correct print head
You can clear the errors in your printer in three reset procedures.
Reset it manually
1. Turn off the printer
2. Press and hold the Resume Button, an indicator light green
3. Press and hold the Power button
4. While holding the Power button, release the Resume button
5. While holding the Power button, press the Resume button twice
6. Release the Power button
7. Press the Resume buttons four times
8. Press the Power button to confirm the operation
9. Turn off the printer
Reset canon mp600 to factory setting (if the first procedure did not work)
1. Press the Home button
2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press OK button.
4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset Settings, then press the OK button.
5. Use the Easy-Scroll Wheel or the up/down arrow to select Yes on the confirmation screen and then press OK
6. Press the HOME button to return to the Home Menu
Final reset (If errors did not clear and or another error appears this will clear it)
1. Press and Hold the Resume button and wait until the printer self restart.
2. Release the Resume button when the printer restart
3. Wait until the printer fully initialize and try printing again.
That will solve it.
Please comeback and give some ratings.
thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do I set time on Jensen VR182
Hold Scroll button, hour will blink, turn left knob to adjust, press scroll button again for minutes, turn left knob to adjust: DONE
Apr 23, 2010 | Jensen Car Audio & Video
Mouse pad buttons don't work properly. Scroll works fine.
Update your drivers, first:
http://www.fixya.com/support/t1381478-webcam_not_working
Then go to Start: Control Panels: Mouse and double-check your configuration for each button.
Dec 15, 2008 | Compaq Presario C700T Notebook
RGB Histogram will not turn off.
It's not hard... I had the same problem, but I found this solution on the internet and it worked.
First turn on the camera and press the play button.
You are now viewing your picture with the histogram.
Use the same joystick looking kind of button that you use to scroll left and right through the pictures, but instead of going left and right, go UP OR DOWN. That scrolls through the different display settings.
Hope that helps!
Dec 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Humminbird 798ci SI Combo GPS Receiver Logo
26 people viewed this question
Top Humminbird GPS Experts
Jerry Greenberg
Jerry Greenberg
Steve
Steve
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
