Reset transfer belt unit counter on NEC IT36C6
  • 18 Answers
SOURCE: need to reset counter for transfer belt
to reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Posted on Jan 04, 2009
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
pdouglasss
  • 125 Answers
SOURCE: I want to reset counters for fuser and transfer
Hi schoeller:
Hope this helps.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press down arrow to highlight Configure Device.
3. Press check to select Configure Device.
4. Press down arrow to highlight RESETS.
5. Press check arrow to select RESETS.
6. Press down arrow to highlight RESET SUPPLIES.
7. Press check to select RESET SUPPLIES.
8. Press down arrow to highlight NEW TRANSFER KIT.
9. Press check to select NEW TRANSFER KIT.
10. Press down arrow to highlight YES.
11. Press check to select YES.
To calibrate the printer, do the following:
4. Press down arrow to highlight PRINT QUALITY.
5. Press check to select PRINT QUALITY.
6. Press down arrow to highlight CALIBRATE NOW.
7. Press check to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
To reset the fuser count
5. Press check to select RESETS.
8. Press down arrow to highlight NEW FUSER KIT.
9. Press check to select NEW FUSER KIT.
The fuser count is reset and the printer is ready to use.
Hope this helps.
Posted on Jul 10, 2009
picipolman
  • 9 Answers
SOURCE: I need to reset the transfer belt counter
enter tech mode by pressing menu>idcopy>left>right>menu>back>menu ,then in data setup clear all memory and clear count
Posted on Jul 28, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: I have a konica Minolta bizhub C250 and the screen
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Posted on Oct 08, 2010
How do i save e mail address
Check manual or tech support. Maybe youtube has video.
Mar 17, 2015 | NEC It36c6 it36c6
C4501 in c451
Laser malfunction; try to reset the equipment as follow:
Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below. Restart it normally and it should work.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Office Equipment & Supplies
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
Mar 29, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
The tools reset the counters for the 'transfer belt unit' (TransferBelt_for2500W(E).exe), the 'fusing unit' (FuserUnit_for2500W(E).exe) and the '2nd transfer roller' (SecondTra
Refer the parts life counter reset.Every time you change the fuser ,imaging unit parts you need reset the counters.Touch the screen exe. nad reset.
Jan 24, 2013 | Konica Minolta magicolor 2500W
I have a konica Minolta bizhub C250 and the screen is reading "replace transfer unit" and "replace fusing unit". I contacted a local repair guy that said he might be able to reset the counters and the...
Transfer Belts
Item # 507-1218-ND
Fuser Units
Item # F2307-ND
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
Need to reset counter for transfer belt
Oct 28, 2008 | Samsung CLP-510 Laser Printer
I want to reset the transfer belt
Unfortunately you cannot as there is a resistor on the unit that blows and resets the transfer counter.
Sorry
J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Reset transfer belt samsung clp-300
Unfortunately you cannot there is a resistor on the unit that when you replace it it blows resetting the transfer counter.
Sorry
J
k24674
jasbo
jasbo
