Question about Panasonic KXTGA740B KX-TGA740B KX TGA740B DECT 6.0 KX-T
KXTGA740 answering system
I AM ABLE TO RECEIVE THE LAST CALL MADE AND NONE OF THOSE MADE PRIOR. I TESTED IT BY CALLING MY NUMBER TWICE AND ONLY THE SECOND CALL WAS RECORDED.
WHAT DOES THIS MEAN IF YOUR CHARGED WITH IT THROUGH THE AKRON COURT SYSTEM 4511.19A2 Description : OVI Refusal W/Prev Off
Don't know how this relates to Air Conditioners, but here is what your answer is
  • 4511.19A2 OVI - Refuses to take a test with a prior OVI conviction in the last twenty years.
I am no lawyer but the way it reads to me, Refused to take a test with a prior operating vehicle intoxication in the 20 years
Prior DUI conviction and refusal to take test DUI
If thats what your asking
Aug 21, 2013 | Heating & Cooling
Can't send or recive Faxes
Try resetting the machine to it's defualt settings.
Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
Seiki 39" LCD SC391TS manual
No, I don't and I don't think Seiki does either. The two I purchased last night didn't have books, batteries for the remotes or screws for the bases. I have called support twice today and received two answers. I sent an email and a tweet. If I don't get an answer, I am taking them back.
Feb 13, 2013 | Seiki Televison & Video
Auto dail in calling mode
maybe your green button (receiving button) is very sensitive, make sure to didn't type twice and typing when are you talking to someone by your face.
if my solution was helpful please rate my answer.
Jul 03, 2012 | Samsung star II duos GT-C6712
Cannot send fax but can receive fax.
You do not give enough information. What happens when you try to receive? Does it ring? Is there any message displayed?
You will have to look through the options in the unit to find the receive settings in the menu. Make sure it's actually set up to receive. Usually there are receive (RX) options such as: manual, fax/tel, fax only, number of rings, distinctive ring and others.
In most cases if the machine is set to manual, you will have to press a button to receive a fax. It may be just the "hook" button, or a start button. Check your owners manual to see which button. In Fax/Tel mode the machine will assume you are using a telephone on the same line. You will have to set the unit to answer after the phone rings a specific number of times(four, for example). After four rings, if you have not picked up the receiver the machine will take the like and receive a fax. If you set it to Fax Only you can set it to answer on any number of rings, but it's best to just set it to one. In this mode the machine assumes it has a dedicated line.
If you have distinctive rings for various people in your home or business then you will have to consult your manual to see how to deal with the different rings.
One last note. Make sure your phone line is plugged into the correct port on the machine. I get a ton of calls at work from people who have the phone line plugged into the extension port, and the phone plugged into the line port.
If none of this helps, you will need someone to look at your fax machine. If you call HP, have your credit card ready.....
Sep 23, 2010 | HP Photosmart 2610 All-In-One InkJet...
Silent calls
You're right. It's in your "fake call" setting. This is activated once you depress the volume buttons (on the left side of the unit) twice.
Aug 13, 2009 | Samsung S8300 Ultra Touch platinium-red...
No answer from other copiers
Hello Sir,
If a fax phone doesn't pick up the phone it doesn't know that there is a fax calling try to call these same numbers and check if you hear some beeps .
May 06, 2009 | HP PSC 2410 All-In-One InkJet Printer
Digital phone/answering machine
The red blinking light is an 'event' light, it does not necessarily mean a message is waiting for you, it will also start to flash if you have a missed call.
click 'up' on the round button to show the missed calls list and it will stop flashing, at least it does on mine!
Dec 26, 2008 | Philips CD4451S/05 Phone
I have a MD8830 and want to use the freesat receiver system for T.V. viewing, the set up guide has an option for a set top box or one for no set top box, can this be used for satellite viewing without a...
If your satellite receiver has an NTSC RF modulated output (RG 59 F connector), you'll need a TV tuner card in your PC to watch it.
If your satellite receiver outputs NTSC composite (unmodulated, RCA cables: yellow, red, white), you can use something like ADSTech DVD Express to connect to your PC using a USB port.
Once you've got your receiver interfaced to your PC or other display, you'll probably need to download the latest programming guides / channel assignments into the reciever using USB or serial cable.
Due to various countries legal restrictions, finding such bin or autoroll files, even for Free to Air satellite programming, is most easily done by word of mouth.
Sep 17, 2008 | Medion Computers & Internet
Panasonic KXTGA740B KX-TGA740B KX TGA740B DECT 6.0 KX-T Logo
18 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
