Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Can't get it back to espresso mode
There is no steam coming out and it won't go back to making espresso
5 Suggested Answers
  • 1089 Answers
SOURCE: Too much water in espresso, Steam spits water
Hi
Yes it is possible to raise the temperature but it requires taking the top off. Most people are not into removing the top. email me if interested
Posted on Jun 01, 2009
  • 80 Answers
SOURCE: after steaming milk, going back to making another espresso shot
try change termostat (small white with two yellow wire)on tank if still doesnt work your computer is gone.
Posted on Aug 27, 2009
EsWorld
  • 1618 Answers
SOURCE: Water is leaking into the drip tray.
Clean the chamber below the white plastic valve, there is also a small discharge that leads from there into the drain tray clean that hole also.
Second the thermostat that controls the steam may be damaged or the cpu board, the contact the controls the steam may be damaged, i have seen both of those happen on some units.
Posted on Oct 10, 2009
  • 1089 Answers
SOURCE: No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Posted on Dec 03, 2009
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
My machine blinking on steam, the wand does not want t o steam, the espresso does not pour. The knob is turned on stand by , but still some steaming noise comes, but no steam comes from the wand, nor...
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
  • Turn from standby to steam then wait for steam light to go solid.
  • When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
  • When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
  • place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
  • make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
  • Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
  • Use fresh beans.
  • Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
  • Try to grind your beans to a good consistancy.
  • Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
  • Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Jan 06, 2011 | Breville Fresca BES860 2Cup Coffee Maker
Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Nov 26, 2009 | Gaggia Baby Espresso Machine
Oct 10, 2009 | Saeco Vienna SuperAutomatica Coffee...
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
After steaming milk, going back to making another espresso shot
Aug 25, 2009 | Saeco Vienna De Luxe Espresso Machine
Gaggia color leaks
Remove the filter and the 2 allen wrench screws that hold the diffuser in place, then carefully remove the spring and valve seat which is probably not in there as they should be, make sure they are seated correctly and re assembly machine. At some thine there was a massive surge of pressure and that moved the valve seat out of place.
Aug 15, 2009 | Gaggia 102534 Espresso-Color...
Does not come off ventilate mode. Re: S-Class incanto sirius mode
Try this push in steam knob when it calls for ventilate, especially if you are steaming or drawing hot water, if that works the the steam valve or the tap rod needs to be replaced.
Dec 28, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
No water flow even though descaling
I started the descaling process as according to manual. I tried running water through every 6 hours or so, however it kept coming up dry. I left the water in for a total of 2 days before finally the water managed to come through.
Mar 12, 2008 | Krups XP4030 Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
23 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
