Question about HP Officejet 4355 All-In-One InkJet Printer
Error de cartucho - HP Officejet 4355 All-In-One InkJet Printer
5 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error el cartucho de tinta 02 de una impresosa hp
HI
You can try
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
  10. All The Best: Pineworks
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: Cartucho de tinta preto incompatível
INK TANK
Posted on Mar 22, 2010
rommelalilin
  • 2178 Answers
SOURCE: despues de camviar los cartuchos de tinta dejo de
Haga clic aqu?.
Posted on Nov 29, 2010
MUKHTAR
  • 2022 Answers
SOURCE: acabo de cambiar los cartuchos
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons
Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on,
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
Hp officejet j3600 error del cartucho
Saludos
Mi nombre es Jose, es un placer intentar ayudarle para ello le recomiendo que limpies los conectores y mires bien cual es el cartucho que tiene problemas, de todas maneras puedes mirar este post.
Como solucionar error en cartucho impresoras hp
Oct 31, 2012 | Office Equipment & Supplies
Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
Feb 24, 2012 | Office Equipment & Supplies
En mi impresora lexmark marca error 1203 ya limpie los contactos de cobre y sigue mismo error
Podría ser debido a un cartucho defectuoso. Trate de insertar un cartucho de diferentes conocidos de trabajo para determinarsi el otro está defectuosa.
Jul 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Tengo un multifuncional x2600 y me marca error atasco de papel, ojala me puedan ayudar...ya cambie los cartuchos ya trate de sacar una impresion y no me permite hacer nada..
Quite las hojas de papel desde el alimentador. Trate de abrir la tapa de la impresora y retire ambos cartuchos. Mientras que la cubierta está abierta, compruebe si hay obstrucciones en la ruta del carro del cartucho. Compruebe si hay conexiones sueltas. Si todo está bien en el área del cartucho, cierre la tapa. Desenchufe y vuelva a conectar la impresora a la fuente de energía para restablecerla. Cuando la impresora se enciende, vuelva a insertar un cartucho en primer lugar. Cierre la tapa y comprobar que no existen errores. Si no, abra la tapa de la impresora de nuevo y vuelva a insertar el cartucho de otros. Vuelva a colocar el cartucho lo que está causando el error que aparezca. Usted también puede tratar de insertar un cartucho de diferentes conocidos trabajando para determinar si el otro es culpable.
Nota: Esto se traduce con translate.google.com.
May 20, 2011 | Lexmark X2600 InkJet Printer
En mi imprsora lexmark me sale error 1203 cual es la solucion a mi problema gracias
El error 1203 son un asunto que ocurre o cuando un cartucho es malo o la Ranura de cartucho de impresora es mala...
1 - intenta de limpiar los contactos de cobre de la ambas ranura de carritos y carrito en la impresora y tratar otra vez.. O 2 - cuando error aparece,
cierre el poder de impresoras lejos; espere un minuto y g?relo atr?s en copia de prensa.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 25, 2011 | Lexmark X4270 All-In-One InkJet Printer
Deseo saber si el cartucho se puede recargar ?y cuantas veces?porfavor........
Los consumidores pueden rellenar cartuchos de tinta s? mismos con un juego, o ellos pueden tomar el cartucho a un refiller o el remanufacturer donde tinta es bombeada atr?s en el cartucho. Los informes del Mundo de computadora personal que rellenaron cartuchos tienen porcentajes de aver?as m?s altos, la impresi?n menos p?ginas que nuevos cartuchos, y demuestran m?s problemas de en-p?gina como pasar como un rayo, rizar, y el color sangran
Jan 14, 2011 | Office Equipment & Supplies
LA MÁQUINA INDICA ERROR E000805-001
1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
3) Abre la cima de la impresora/multi unidad de funci?n.
4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
9) se Asegura de que no hay agua que queda en el cartucho.
10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
11) Reinserta el ladrillo/bloque del poder.
12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
13) el Poder en la impresora y el error debe ser resuelto.
14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
Dec 19, 2010 | Office Equipment & Supplies
Tenemos una t160 y en el visor da el siguiente error "32 cartucho no soportado" pero tampoco se puede acceder al menu propio del equipo.¿Cuales serían los pasos a seguir para...
reviza que que sea el cartucho correcto
trata de quitar todos los cartuchos y encenderl a impresora sin los cartruchos instalados
instala los cartuchos de nuevo
si no funciona prueba los mismos pasos pero al encender de nuevo la impresora deja precionado el boton de encendido por 30 sec o mas para hacerle un RESET al sistema
SALUDOS!!!!!
Aug 11, 2010 | Lexmark Optra T610 Laser Printer
HP C7280 All in One Printer: Ongoing error to change ink
Hola. Si el cartucho es nuevo, devuelvelo, es el cartucho que esta defectuoso.
Pero si es cartucho ha sido recargado lee las siguientes lineas:
Tienes que decirme si los cartuchos was refilled, porque en ese caso la impresora no los va a reconocer como llenos., la razon es porque los cartuchos tienen un "contador electronic" que solo analiza informacion de cuantas hojas se han impreso, y al momento de ser recargados solo les colocan tinta, y el contador sigue marcando vacio.
Si aun con este mensaje puedes seguir imprimiendo, no te preocupes, pero si no, por favor dejame saber el modelo de tus cartuchos como respuesta y te mostrare como resetear.
Apr 04, 2010 | HP PSC 2175 All-In-One InkJet Printer
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
HP Officejet 4355 All-In-One InkJet Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
