Question about Samsung SRP 350 Thermal Printer
Not clear printing
Portion of printing is not clean
Brother dcp 7040 prints and then prints too light
Before refilling, clean entire cartridge units. Remote its cleaning blade and clean it with an IP solutions and make sure no bends in cleaning blade. Do not mix new toner powder with old one. Also clean plastic portion below the developer roller also. Then the same complaint found, clean the LSU unit of the machine. Now it work properly.
Feb 10, 2015 | Brother DCP-7040 Laser Printer
My Canon 8530 printouts has wiped-out/faint prints in between prints. when you at the photocopy made by canon 8530 copier, you will see that some horizontal portion of the copy are faint or wiped-out and...
hi
please press the maintance of the printer and perform a Clean Print Head operations
either form you PC or from the printer directly.
Clean the print head and you should get better output
good luck
Aug 29, 2011 | Office Equipment & Supplies
In printed side some portion of printing is very light l
1) CLEAN THE OPTICAL SYSTEM i.e. MIRRORS LENS REFLECTORS.
2) CLEAN THE DUST GLASS ABOVE DRUM UNIT.
3) CHECK LIFE OF DRUM AND CHANGE IT IF REQUIRED.
Jun 12, 2011 | Canon imageRUNNER 400S Copier
After cancing colour cartridge, it dont print colour anymore.
Double check the cartridge to make sure there is no packing tape still over the print head, make sure it is not expired if there is a expiration date on the cartridge. Next try a clean print head cycle on the cartridge and you may even clean the print head portion of the cartridge manually using a little alcohol soaked onto a q-tip. Does the printer still print black? If so it is always possible you got a bad cartridge.
Mar 07, 2011 | Lexmark X1290 All-in-one Inkjet Print...
The top portion of the text in each line is not printing. I have cleaned the ink cartridge, but the problem persists.
1. Shake ink cartriage and Re-clean the print head, dripping alcohol to drain off and wipe clean w/tissue (do not touch with fingers).
2. Apply slight suction to print head to clear clogged ink (if by mouth, spit out ink and water rinse etc.).
3. Re-clean per step 1
4. Insert ink cartiriage, seating it all the way into holder.
5. Run a "cleaner sheet" through printer to clean al printing parts
("cleaner sheets" are available at office supply stores).
6. Printer should print all parts of letters.
Jun 10, 2010 | HP DeskJet 612c InkJet Printer
The black ink cartridge is not empty but it won't print anything black. Will print colors.
Probably your ink cartridge is clogged. Try to clean it first by using your printer cleaning software. If it does not work, take out the black cartridge clean the portion where the ink is coming out using a cotton and a cleaning solution (water and alcohol will do). Repeat the procedures if necessary.
May 12, 2010 | Lexmark X2600 InkJet Printer
Black ink cartridge
try clean the cartridge nozzles and printers ones aswell.
Jan 03, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
My copier smears the middle portion of printed documents.
Cleaning the roller (drum) may have made things worse. You will need a new toner cartridge. However you should try and get a replacement from your supplier if the cartridge is not too old
Jan 02, 2009 | Canon imageCLASS D661 Digital Printer
Hp officejet 7110
1st how old are the cartidges ink could be solidified.
2nd did you take the plastic off of the new ink heads?
try runninng clean pint heads from printer control
Jan 04, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Samsung SRP 350 Thermal Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
