Question about Bunn CWTF15-TC
How to adjust water level on bunn - Bunn CWTF15-TC
  • Bunn Master
  • 2,236 Answers
Use a measuring cup or bucket that goes up to 64 ounces in order to accurately callibrate. also, delime the sprayhead with a flathead screwdriver or paperclip first to ensure proper flow
Posted on Jan 15, 2015
5 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Posted on Aug 14, 2009
EsWorld
  • 1618 Answers
SOURCE: using Bunn CTF15 autofill connection to water
The solenoid is leaking, replace and the problem will be gone.
Posted on Oct 07, 2010
EsWorld
  • 1618 Answers
SOURCE: how do i adjust the
Remove the front panel there are instructions on increasing the water level.
Posted on Feb 19, 2011
EsWorld
  • 1618 Answers
SOURCE: I have an Axiom Bunn automatic coffee maker that
Remove the front panel there are instructions on changing the level.
Bunn water level
What about Bunn water level? Too high? Too low? Not filling? Leaking?
Jun 22, 2014 | Bunn CWTF Coffee Makers & Espresso...
Coffee brewing very weak
possible ways to remedy this problem:
problem of weak beverage
solutions:
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
extraction.
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
Apr 11, 2013 | Bunn 392 Pourover Coffee Maker With 2...
How do i adjust the water level on my Axiom Bunn coffee maker? It only brews about a half of a pot.
Feb 18, 2011 | Bunn AXIOM-35-3
My bunn cwtf 15 wont put out hot water and the ready light wont turn off dustain
If your ready light is on and your water is not warm... sounds like the thermostat is too low. Inside the front panel (behind the brew basket) there is a thermostat adjustment on the left-hand side. If you turn that up your ready light should shut off. You can then adjust the temp to your desired level. (194-200 degrees depending on roast, grind, etc...)
Jun 14, 2010 | Bunn CWTF15-TC
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
Aug 14, 2009 | Bunn NHB Coffee Maker
Water over filling pot
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Bunn CWTF15-TC Logo
165 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
