Question about Reddy HEATER R70DT 70,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
Runs when started but won't stay running
I have a heater that will run when first started and it runs for about 20 min. It runs good. But then it shuts off. After waiting about 1 min. it will start right back up but only for about 10 min. Then it shuts off again. The more times I run it the less times it stays on. I have cleaned the nozzle and filters and such. It has clean fuel. What is my problem? And what should the settings on the 2 screws be? Thanks for any help.
5 Suggested Answers
  • 5 Answers
SOURCE: Heater will run for about 5 min. Than flame goes out , and smokes
MAKE SURE THE HOLE IN THE K1 CAP IS CLEAR.SOUNDS LIKE A FUEL AIR MIX PROBLEM.
Posted on Dec 17, 2008
tinytrees
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
  • 5 Answers
SOURCE: heater runs for 10 20 min shuts off. cleaned photo
Wow... what kind of heater, what kind of fuel.... "photo cell"...LOL>...get some facts and I can get you an answer...derrrrrrrrr
Posted on Dec 10, 2009
hardrocko
  • 1476 Answers
SOURCE: R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Posted on Feb 03, 2010
2000 jeep grand Cherokee cuts off in 29 min cools off runs 20 min
which engine>>
so you have 20 mins to find the cause, not sit and drink beer.
check for spark.
on all cylinders........ using the 100 year old way, we all should know.
ok say spark is good (if bad , scan it while bad, bingo got DTC>?)
sparks good
i NEXT use test fuel.
it starts and runs
it starts and stalls in 3sc
or does nothing
IN this order, unless want to do compression test hot fail.
watch scotty , do his magic. (100 years old this, magic, now.)
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
Sep 14, 2014 | Jeep Grand Cherokee Cars & Trucks
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
91 dodge stealth will run and idle fine for 10to 20 mins then starts to misfire
yes as will a cracked distributer cap, and a bad coil will only fire when it decides to having a nomiss nomiss miss nomiss situation.
Dec 13, 2013 | Cars & Trucks
Headache
You might need a new starter what's happening is when the starter heats up it won't start up again until it cools off
May 30, 2013 | Vehicle Parts & Accessories
CAR WON'T START AFTER CHANGING BATTERY
it is in theft mode. you will need to turn the ignition to the run position and the theft light will blink. leave on for about 15 min. turn key off then turn back to run position without trying to start it. leave in run position fo another 15 min. turn off then try to start. should start
Jun 13, 2012 | 2005 Saturn ION
Honda accord 1994 will start but won't stay running
Does it stall as soon as you let go of the key
Jan 15, 2012 | 1999 Honda Accord
PRELUDE WONT STAY RUNNING
see http://www.tegger.com/hondafaq/faq.html#general under EFI Main Relay (half way down page). Probably Main Relay fault - read the links etc.
Jun 14, 2009 | 1992 Saturn SC
WON`T START COLD, STARTS ON STARTING FLUID 96 TRACKER
96 , TRACKER?
IF IT RUNS AND STAYS running. then that means the car is flooding or is in a sad state of tune.
tune it up and it will start every time.
if not ask me here.
http://www.kick-fix.com/
see my guest book. ask a question.
1; tune up
2: bad ECT sensor.
3: stuck closed IAC.
my page answers all sidekick questions.
Feb 04, 2009 | 1992 Geo Tracker
Heating & Cooling Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
