Question about LG Televison & Video
I want to chang the setting,vertical size and agc setting. i dont know how to unlock the code. tv model is ct21q60e
Model ct21q60e
2 Suggested Answers
  • 153 Answers
SOURCE: need fuse size
AGC-7 is a 1-1/4" X 1/4" glass tube fuse with metal ends rated for fast blowing at 7 amps. You should be able to get this fuse practically anywhere. Including radio shack.
Posted on Apr 26, 2009
When you turn on the tv it turns itself off after several seconds before you ever get a picture
All projection TVs have built in safety circuits in case of a malfunction. There maybe an indicator on the set that blinks after it shuts down (not all models have this). This is an issue for a service shop as auto shutdown is reserved for the more serious issues.
A likely problem with the vertical circuits (top to bottom part of the picture) or the high voltage circuits. You will need a technician.
Mar 21, 2010 | Philips 55PW9363 55" Rear Projection...
Apex AT2702 27" color television under scan
well most of the modern tv today doesnt have vertical hold anymore.
this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Sep 18, 2008 | Televison & Video
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
Need to unlock my tv
go to parental control and give the pass code
it wil get unlocked
Jun 21, 2008 | Sony RMT-V202 Remote Control
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
Need fuse size
Apr 26, 2009 | Audio Players & Recorders
Daewoo 2001 cd player security code
If all else fails, TRY THE CODES BELOW, which were the most common codes used in models during the 1998-2001 model years. 4316
2152
4513
4362
1156
2145
3451
6361
5624
5241
3346
1165
3241
4524
5436
Dec 14, 2008 | 2001 Daewoo Lanos
TV screen shows 'SKYWORTH' when turned on. Activated this by mistake and can not get back to previous mode. This caused channel reception to be bad and all channels are either not showing well or showing...
HI I have the same problem There are things you can do... For the tuning problem I suspect changing the "RF AGC" will fix that. You need to go into service mode. Turn off TV then hold Vol + and - on front panel and turn on. The TV will come up with extra service menu. Just keep pushing menu till you see "RF AGC" and dont change any values untill you write down what they are or take photo etc. Then just change the "RF AGC" value and see how you go with the tuning. ALL THE BUTTONS ABOVE ARE ON FRONT OF TV. NOT ON REMOTE....Hope this helps....
Jun 10, 2008 | Televison & Video
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Vertical size
make checks on your vertical it could be getting too much voltage replace it along with some cap around that are not filtering the voltage to the ic.because it have cause damage to your vertical change all related components in that circuit also check the related circuits.you can get a schematic for your set at www.samsphotofact.com good luck
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
Televison & Video Logo
20 people viewed this question
Computer Repairing
Computer Repairing
