Question about Bowflex Treadclimber
Bowflex treadclimber error code l5 - Bowflex Treadclimber
5 Suggested Answers
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
  • 3 Answers
SOURCE: my bowflex treadclimber tc500 is
where are you located
Posted on Nov 21, 2010
  • 679 Answers
SOURCE: my bowflex treadclimber starts for abut 3sec then
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Posted on Jan 22, 2011
ercupa190
  • 12223 Answers
SOURCE: bowflex treadclimber gives error code h13 h24
this a problem with a bad design from a factory. You must call to service support a explain this error. Is a problem,with a PROM AND EPROM.
However you can try to RUN the software calibration for diagnose, and troubleshootingl.
God bless you
Posted on May 09, 2012
How do I fix L5 error on a Bowflex TreadClimber tc3000
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 22, 2016 | Bowflex Exercise & Fitness
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
Feb 02, 2016 | Bowflex TreadClimber TC5000
Why am I getting an L5 error and the belt stops?
Do not know, but here is a pdf that not only is a user manual but also shows how to take apart and fix problems.
Maybe the 92 pages hold an answer for you.
http://download.dfxi.com/supportdocs/SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Dec 01, 2015 | Bowflex Treadclimber
Err L5
this meand 2 alternatives:
1) problem with the display board adjust the reed switch
see the diagram
2) mean the elevation motor; lube the gear and shaft ,and adjustment the potentiomenter, and check the voltage input motor .
God bless you
Jun 20, 2012 | Bowflex Treadclimber
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
Jan 22, 2011 | Bowflex Treadclimber
My bowflex is showing "err l5" what is wrong with it?
This error indicate that the console is unable to deter mine the speed of the belts. Potential parts associated with this are the Speed Sensor, MCB, Motor, I/O cables, and Upper Electronics. Call Nautilus Service Dept 1-800-628-8458
Apr 14, 2010 | Bowflex Treadclimber
My Bowflex Treadclimber keeps coming up with an Error L5. This error message shows up 5 seconds after turning the machine on. My husband looked it up yesterday and said that the machine needs to be...
L5 due to the screen is actually LS (lost signal) the first place to check is the gap of the speed sensor. under left treadle 2 black wires. Removing the rear covers will allow you to see the lwr cntrl board and move the belt by hand. The gren led light should flash once per revolution of the drive pulley. If not then it is the speed sensor. Adjust sensor to pully about thickness of a credit card. then calibrate unit.
LS is also tripped by any broken wires or bad connections. Start at sensor and board first.
Jul 21, 2009 | Bowflex TC3000 Treadclimber
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
The tracks do not work. it shows E5-5 in the timer box
I have an error code Err L5 this happened after my machine main power has been turned off.
Mar 08, 2009 | Bowflex Treadclimber
Bowflex Treadclimber Logo
13 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
