Question about Microsoft XBOX 360 ARCADE Console
Xbox tray gears on left are not lined up
Gears that move tray are stuck
3 Suggested Answers
  • 45 Answers
SOURCE: xbox 360 plays all games except gears of war
is there any firmware up updates that you can download
Posted on Jun 05, 2008
  • 11 Answers
SOURCE: MY xbox tray got knocked
They tray hasnt been aligned correctly or you could have damaged the tray?
if you dont have the skills to repair this yourself i would recommend www.ltrepairs.co.uk
Maybe they can supply a new drive or repair yours.
Posted on Sep 09, 2011
Tray stuck open
The gears on the Xbox 360 have become misaligned. Here is how you fix it. If the tray is out all the way disconnect the power.
Step 1:
Locate the tab on the left side of the tray.
Step 2:
Lift the tab with a pen or equal and pull the tray out.
Step 3: power on the Xbox 360 and hit the eject button. When you here the eject "ding" pull the power. Now the drive is in eject mode and the cogs are aligned to take the tray.
Step 4
Gently place the tray back in and slight nudge to engage gears.
Step 5
POwer on xbox 360 and give another nudge to help the tray realign.
Step 6
Open and close the tray a couple times. To assure sucess.
Aug 20, 2014 | Microsoft Xbox Video Game Consoles & Games
Xbox 360 tray taking 5 or 6 times to open
You will probably need a new DVD drive. If you are experienced with disassembly, you could try cleaning out the drive gears in the DVD drive. If you have a game stuck inside of the drive, there is a small hole in front of the drive, behind the faceplate, that will accept a straightened paperclip and manually drives the tray gears,
Feb 02, 2014 | Microsoft Xbox 360 Console
Xbox tray is off gears and stays open howe to fix?
It's very difficult to change the door on the XBox without causing any damage. I recommend you have it send to someone who professionally knows how to assemble it correctly. I know videogame911.com fixes this sort of problems, they did something similar on my system and cleaned it all out. Give them a try!
May 03, 2013 | Microsoft Xbox 360 Console
A game is stuck in the tray. The green light is
There is a way to manually remove it. First you will want to unplug the power for a few minutes to let your Xbox reset. Re-attach the power cord and see if you can now eject your DVD. If that did not work turn the power off and unplug it. Remove the faceplate on you Xbox console. You will need a thick paper clip or something similar. Straighten one end of it out. With the faceplate removed you will see 2 small holes right underneath the DVD player and one hole to the right.
Since Microsoft decided to use 3 different DVD drives the procedure will vary. If you have a Samsung or Toshiba drive use the small hole on the right. Should be right underneath the X on the DVD drive faceplate. Push your straightened paper clip in the hole until you feel it hit the gear. The gear needs to be spun from left to right. Poke around until you find it then push in gently until you feel it move. You will see the tray start to move out.
For Hitatchi DVD drives go for the first hole on the left. Beng DVD drives will use the middle hole. This requires the most pressure to get the gear to turn. You will see the tray start to move take your time and do not push too hard in case you are missing the correct spot. Once the tray starts to eject you can pull on it slightly to help it open. You should now be able to remove your Game.
Nov 17, 2009 | Microsoft Xbox 360 Console
My xbox disc tray will not close
The tray component gears were probably stripped and the tray is now shifted vertically to high or low. Because when the tray moves back and forth the inside eye set up moves into the disc to hold it. Solution Have X-Box fix you problem for around $80 or less. Call 1-800-4MY-XBOX. They will send you a postage paid box. Also check to make sure nothing lose was in the xbox and also try to slam the door hard over and over as it try to slid in itself.
May 28, 2009 | Microsoft Xbox Console
My xbox 360's disc tray will not close
try to force it to close. usually stuck gears cause this problem.
Apr 30, 2009 | Microsoft Xbox Console
I cannot get my disc to eject from the xbox
open it up one of the gears may have been broken
Feb 23, 2009 | Microsoft Xbox 360 Console
Prints crooked
your printers gears have got mis-aligned or may be even your paper feeder tray is not availble or not fitted properly, for gears problem u get your printer serviced.wish u success!!
Jun 04, 2008 | Epson Stylus C88 InkJet Photo Printer
Xbox 360 drive doesn't always open
Can you hear any gears grinding when you try and eject it? Has anyone ever pulled or pushed the tray in roughly?
Sep 30, 2007 | Microsoft Xbox 360 Console
Xbox 360's disk tray will not open
The motor that opens the drive tray could be bad or there could be something stuck in the gears. You may have to take the Xbox apart and pull out the drive and then take it apart to see if there is anything stuck in there.
Jun 22, 2007 | Microsoft Xbox Console
Microsoft XBOX 360 ARCADE Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
