Question about Kohler Plumbing
TUB SPRING CLICK DRAIN
DOES NOT LOCK
    Top Expert:
  • 3,698 Answers
Www.us.kohler.com/us/...Support
Posted on Aug 20, 2014
I keep having a dE error message on my LG washing maching
Samll d with big E = Dorr Error. (Cap D with E = Drain Error) Replace your door lock / latch. To get to it, you can either take the spring clamp off the tub seal around the outside of the door opening, removing the outer part of the tub seal, or if you have long thin arms, reach it from the top once you have removed the washer's top. Remember to unplug the machine before working on it.
Mar 06, 2011 | LG Washing Machines
My front loader leaks water because the door gasket, called a boot I believe, is torn and needs replacing. There is nothing in the manual that gives even a clue as to how to remove this boot or how to...
There should be a spring loaded clamp on the outer panel and a screwed together wire clamp on the tub. You may have a water inlet clamp on this model and possibly a drain clamp at the bottom center. Take your time so you do not tear the new one. If you are really a go getter you can remove the top panel of the machine, the control panel, the door lock, the bottom panel and the entire front of the machine to gain easy access to the tub side of the boot. Remove the outer spring loaded clamp first before attempting to remove the front panel.
Sep 18, 2010 | General Electric WBVH5200J Front Load...
Drain in the close position the drain handle is not working
Remove the 2 screws on the drain cover in the bath tub to gain access. Drain plug should be connected to trip lever on drain cover probably using a cotter pin with ends bent to keep it on. Do not yet remove the cotter pin.
To know for sure if it is the trip lever broken, you can hold the trip lever down and tub will drain. If you let go, trip lever on cover returns to upright position and stops draining. You can also feel the spring tension stay on it when you press the trip lever down. Most likely, the drain trip lever (spring action) which is a part of the cover itself is broken.
First have ice pick, thin screwdriver, (even a large paper clip (or 2 for strength) bent straight may do) or anything small enough to go through same hole in drain assembly as cotter pin, while long enough to go across hole in bathtub to hold drain assembly up till you install new drain cover attaching it to assembly with same or new cotter pin.
Now unbend the cotter pin (sort of looks like a heavy duty metal bobby pin) ends using pliers. Using pliers pull cotter pin out while holding drain assembly so it will not fall back into tub wall.
Next secure assembly using the above ice pick or large paper clip while you take trip lever (which is the cover)
to hardware store, etc. to pick up generic tub trip lever.
CHANCES ARE THE ABOVE SOLVED PROBLEM, BUT IN CASE IT WAS NOT THE TRIP LEVER WHEN YOU TESTED USING THE METHOD ABOVE TO DIAGNOSE THEN BELOW IS HOW TO REMOVE ENTIRE TUB DRAIN ASSEMBLY
There is a metal stem with a threaded rod coming up in it with a nut on it, and on the end of this is a round metal weight looking much like a very small upside down can. you will not be able to see all this unless it is neccesary to remove entire drain assembly which you can then take it to a Home Depot or Lowes type store to replace. Most can be replaced with a generic tub drain.
Now to get the assembly out once you've removed the 2 screws gently work metal stem assembly up and out at a slight angle. You may have to move nut on assembly to shorten the length in order to get it to clear the tub. IMPORTANT! If so, 1st mark the position of the nut on the threaded rod so you can put it back in same position when reinstalled before lowering assembly all the way back into tub wall.
Apr 17, 2010 | Home
A coin fell into the basket and rolled into the gap at the edge of the wash plate. I took the plate out but the coin was not there. It must have fallen into the larger slots beneath the wash plates. If I...
The coin will not drain out nor be fed back into the tub by the recirculation pump but it will block the filter or eventually block the impeller of the drain pump and break it. You'll then experience a draining problem and need to replace the drain pump.
What you have to do is remove the basket to get the coin out then take the opportunity to clean the filter vanes. The coin is most probably still in the filter.
Tape the lid to the top of the washer then disconnect power to the washer.
The top of the washer is held to the front of the cabinet by two locks located about six-and-a-half inches away from the outer edges of the washer. Use a putty knife blade or similar tool to press and unlock the top locks.
Insert the blade of a putty knife into the seam between the top of the washer and the cabinet at the given distance from the outer edges of the washer. Press the locks then lift the top of the washer.
Remove the impeller (wash plate) cap by inserting the blade of a flat-bladed screwdriver or similar tool into the slot in the impeller cap, and then pry the cap off.
Remove the 7/16" hex-head bolt from the impeller (wash plate), then lift and remove the impeller from the basket.
Pull the recirculation hose off the tub ring by compressing the spring clamp holding it in place. Remove the tub ring by prying and unsnapping its tabs from the tub.
Lift the basket out of the washer to access and clean the filter. Remove the two screws holding the filter to the tub. Take the filter off and clean it.
Reinstall the filter, the basket, and the wash plate. Secure the wash plate with the 7/16" hex-head bolt then snap the impeller cap in.
Put the tub ring in place aligning the tabs then snap the tabs back into position. Reinsert the recirculation hose into the tub ring and secure it with the spring clamp. Push and lock down the top of the washer to the cabinet.
In case the coin is no longer in the tub or in the filter, turn off the water supply to the washer. Disconnect the fill hoses from the rear the washer and remove the end of the drain hose from the laundry tub or stand pipe.
Place padding or cushion on the floor fronting the washer, and then carefully lay the washer on its front panel to access the drain pump at the bottom of the washer.
With the washer facing down and you facing its bottom, the drain pump is on the left while on the right is the recirculation pump. You can actually see the drain hose connected to the drain pump.
Using a pair of pliers, compress the spring clamps holding the drain pump inlet and outlet hoses. Move the clamps away from the pump then remove the hoses.
Remove the three 5/16" hex-head drain pump mounting screws. Open the wire cover on the pump then disconnect the wires from the terminals of the pump, and then remove the pump from the washer.
Check the pump impeller for any debris and clean it. Reinstall the pump after cleaning and secure it with the three 5/16" mounting screws. Reinsert the inlet and outlet hoses then secure it with the spring clamps. Make sure the tab on the outlet hose connector fits into the slot in the outlet hose.
Reconnect the wires to the pump terminals then close the wire cover.
Mar 10, 2010 | Whirlpool WTW6400SW Cabrio Washer
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Drum seems out of balance does not allow water to drain because water pump hose kinks
Hi, you will have to open machine, and check spring, maybe one of your spring are broken, or strain, first lift top, and remove sides of machine, put hands on tub and rock complete assemble back until tub centers, if tub is tilted left, spring on opposite side, is loose or broken, if broken, replace, but most time they slip out, this is cause, if machine are overloaded, or not level properly, when washers are not properly leveled, when they reach spin cycle, they could go outside and come back in, just making a point, check you machine level before you start. good luck.
Aug 07, 2009 | Maytag PAV3240A Top Load Washer
Washer won't drain -- clean the pump
First I would try to flush the pump, if the tub is still full of water. To flush the pump, take a garden hose sprayer and fit it tight into the drain hose. Give it a short shot of water, then stick the drain hose back into the drain. Put the washer on spin and see if any water comes out. You may have to do this more than once to clear the pump. If that does not work, siphon the water out of the washer and disconnect the hose from the pump to the drum. Clear the hose the best you can, pour a little water into the drum to check it. Check the pump too, take it apart if you have to.
May 05, 2009 | Washing Machines
Bath tub drain
You need to replace the overflow cover with the lever on it.You can replace the entire piece or just the faceplate.There is a spring on most of these that holds the lever in place when thrown and that is the piece that is broken causing your issue. Thanks for using Fix Ya.
Mar 02, 2009 | Delta T13420 Chrome Classic Single Handle...
Plumbing Logo
281 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
