Question about Panasonic KX-TG5631 Cordless Phone
Panasonic kx-tg6722e has blank display screen, batteries are charged
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
SOURCE: No dispaly on screen.
I fixed mine by opening the handset case, and discovering that nothing was wrong or corroded, except that one of the charger contacts (the big and shiny long ones at the bottom of the handset) was a little loose. The two screws at the bottom of the circuit board also hold the contacts in place. Make sure they're tightened if they seem even a tiny bit loose.
The LCD was totally fine, and my contact ribbon for that was held in by tape and glue, so there was no way to check for internal corrosion KX-tga560m.
Posted on Jul 15, 2008
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
SOURCE: Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Posted on Sep 15, 2010
SOURCE: KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Posted on Oct 23, 2010
How can i put my phones KX TGA641C in French?
PDF]Operating Instructions - Panasonic Canada
https://panasonic.ca/PCS/.../KXTG6411-12-13-14-OI-Eng.pdf
Panasonicappropriate service offered by your service provider/telephone company. .... Feature.KX-TGA641C. KX-TGA740C. KX-TGA840C. Handset. Display colour/ size ..... "Fran?ais" as the display language. .... This feature allows you to put an outside.
[PDF]Installation Manual - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tga641_im.pdf
PanasonicNov 19, 2008 - Charge the batteries for about 7 hours before initial use. Additional Digital Cordless Handset. Model No. KX-TGA641. Installation Manual.Missing: french
Dec 17, 2015 | Lands Phones
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
Blank display screen
I got my display to come on while on the base unit, by making charging contacts connect. When I did this, then battery indicated it was low, then though I had taken it out a working phone. Maybe the fact is one of charging units are not charging correctly if have several. I have a 3 system unit and it is the base that seems to have the problem.
Aug 28, 2013 | Panasonic KX-TG5622 Phone
I have not used my Panasonic KX-TCD200CX cordless a Month. Now when I plugged it in, it does not seem to be charging. The screen is blank even after 5-6 hours of charging.Please advise what I should do...
Possible that the battery Voltage has gone BELOW the THRESHOLD level and so will take a long time to come up so that the display light ups. It is best to see if the battery is leaked, damaged or the connectors clogged. Test the voltage on the battery and replace if the voltage is low. Also keep the phone plugged on overnight so that the circuit warms up and clears all disturbances.
Jun 17, 2011 | Panasonic GigaRange KX-TG5432 Cordless...
Battery works. Won't turn on
I have the exact same phone and exact same problem. Phone is charged in cradle and green light (indicating full charge) is lit on handset. Opened it up and everything appears clean as a whistle. Did the original poster find a solution? if so, please post it. Thanks.
May 27, 2010 | Panasonic KX-TD7896 Cordless Phone
The display screen is blank, phone still works. How to fix?
I am having the same problem with my KX-TGA234W. One day the screen just went blank, so I changed the battery, but it still is blank. I hope that someone can help both of us.
Apr 18, 2010 | Panasonic KX-TG5632 Phone
Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Jan 23, 2010 | Panasonic Lands Phones
Hello -need help with phone
It's not charging the battery, clean the contacts on the base, put it on another base to see if it says CHARGING.
Verify that you have power to the base.
Battery might be bad. Try it in another handset.
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Panasonic KX-TG5631 Cordless Phone Logo
79 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
