Question about Sennheiser OFFICE RUNNER Headset
Wont turn on
No power to headset
Ps3 afterglow bluetooth flashes red and blue and wont let me talk, what do i do?
When the afterglow headset flashes from red to blue, it is in pairing state, youve held the power too long after power-on. Shut it off again and turn it back on and dont hold the power button untill it flashes red to blue. The directions provoded with it aare quite easy to follow. Took me 30 seconds to set mine up
Apr 09, 2012 | Mad Catz Radio Communications
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect...
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
MY I776 WONT FIND MY BLUETOOTH 220 WHAT CAN I DO
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Jan 20, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My blue tooth wont turn back on, will sun exposure
exposure to high temps will kill a bluetooth headset so will cold temps. Did you try recharging it? if you did and it still wont turn on then im afraid its cooked.
Aug 09, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Why wont my bluetooth h300 turn oni changed the battery because i thought that was the problem but noe its like theres no power it just wont turn on no blinking lights or anything
Did you hold the call button down for more than a few seconds?
Check the manual out to make sure your doing the correct process.
Link- http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
Jul 16, 2009 | Motorola Mobility H300 Wireless Headset
My Lg Decoy wont sync with my Motorolla bluetooth
Jun 05, 2009 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Red light wont go off headset wont turn on
SImply connect the headphones to a power source. Then press up and down volume buttons at the same time. It will reset the headphones.
Dec 08, 2008 | Insignia Bluetooth Wireless Headphones...
Sennheiser OFFICE RUNNER Headset Logo
47 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
