Question about Panasonic NRB30FX1XB Bottom Freezer Refrigerator
Panasonic NR-B30FX1-XB Refrigerator displays 0
Display screen reads 0 and the fridge is too warm
5 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Display not reading properly
Try this first
Open up the doc feeder
unplug the power cord
hold down the pointed switch behind the small glass strip while plugging the power cord in
close the doc feeder
scroll down to SHIPMENT SET
press SET
press 2 for no
wait for machine to intialize.
if this doesn't work you have a bad LCD display.
Posted on Jun 22, 2009
  • 4090 Answers
SOURCE: dvd player wont read displays H2O panasonic 2001 model
try cleaning the scanner eye with the cleaner disk
Posted on Aug 19, 2009
  • 13 Answers
SOURCE: Panasonic KX-B530. On power up "0" on display for
Sounds like either the fluoro has died. When you turn it on, is there any fluoro lighting coming out from behind the edge moulding on either side????
Posted on Nov 20, 2011
ercupa190
  • 12223 Answers
SOURCE: Panasonic Phone display reads "BAD EAR" ?????
PLEASE read your owner manual, section troubleshooting and reset the microwaves.
Otherwise you mus call to the company Panasonic, and get support ONLINE via phone or chat, for to resolve the problem. Can be a problem with the eleactronic board PROM.
God bless you
Posted on Sep 10, 2012
I have a BEKO MODEL GN162320X the temperature display shows 0 in the freezer section and 33 in the fridge section can I reset the display
If you wish to get some details about refrigerator troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator..." http://electro-medical.blogspot.com/
Jan 22, 2017 | Beko Refrigerators
The display stopped showing temps and displayed a "6". The actual temperatures dropped to freezing. I unplugged the unit a few times for up to 2 days but the same issue developed.
Whirlpool Refrigerator Error Code: Flashing 6 on the fridge display
Condition: The 6th Sense technology is activated - If you put warm food in the refrigerator or leave the door open, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Part or Parts: Allow fridge to get back to temp on its own (no parts required)
Whirlpool Refrigerator Error Code: 6 on the fridge display
Condition: Computer error
Check: Remove power for 5 minutes
Part or Parts: If code returns replace mother board
Apr 29, 2016 | Avanti Refrigerators
CL flashing even though the coils have been cleaned. unable to reset wine fridge
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Jan 12, 2014 | Marvel 30WCM Wine Cooler
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
French Door Refrigerator- attempting to adjust refrigerator and freezer temperatures to 0 and 38 respectively.- Came about when changed water filter and refrigerator temperature jumped to 68. Attempting to...
Should read -18 C for freezer and 5 C for fresh food That corresponds to 0 F and 38 F. Give me the modal off the fridge and I will tell you how to switch from Celsius and Fahrenheit or check your book
Nov 22, 2010 | KitchenAid Refrigerators
My digital display reads 88 degrees for the fridge and the freezer. The 88 display on the right is flashing. None of the buttons work when pressed.
reads 88 deg/ ok is frig that warm also .. if so replace the p c control as it has gone bad . in some models they call it a jazz board . / there is a update and it works much better .. mm
Dec 23, 2009 | Samsung RF265AA Bottom Freezer French Door...
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Panasonic NRB30FX1XB Bottom Freezer Refrigerator Logo
74 people viewed this question
Top Panasonic Refrigerators Experts
Lawrence Oravetz
jhnolson
Are you a Panasonic Refrigerator Expert? Answer questions, earn points and help others
