Consol tw70_508sd dryer not working
Drying and Lid Locked lights flash red and it beeps continuously. Dryer will not start.
look on coolblueworld.com or paperwork for error code is in back consol . please unplug dryer if you remove consol.
Mar 21, 2015 | Fisher and Paykel SMARTLOAD DE62TG1...
We have a whirlpool duet front load dryer, why does it beep during a cycle?? when clothes are still wet?
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
May 21, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool dryer model LEQ8858JQ0 - won't turn off by its self, just runs and runs no matter what cycle it is on.
  1. Access the Timer
    Test the Timer
    Replacing the Timer
Apr 18, 2011 | Whirlpool LEQ8000JQ Electric Dryer
How to replace on switch
  • Unplug the Frigidaire dryer from the wall outlet and move the dryer two feet from the rear wall.
  • Locate the screw on each end of the control console, securing the console to the dryer top. Remove the screws with a Phillips-head screwdriver. Lift the front of the control console and rotate the console toward the back of the dryer.
  • Remove the three hex head screws that secure the rear of the top panel to the dryer with a nut driver. The three screws will be on the top rear edge of the top panel.
  • Grab the top panel on each side and slide the panel forward. This will release the front spring clips that secure the front of the top panel to the dryer. Lift the top panel off the dryer and set the panel out of the way.
  • Dec 23, 2010 | Frigidaire Dryers
    LED Display
    You can find the display PCB assembly at any LG authorized parts distributor and it is part number EBR36858901. It can be replaced easily by removing the top panel and the console. Unplug the dryer before servicing.
    Remove the screws securing the top panel to the rear of the washer and slide the panel to the rear of the dryer. Lift the panel off and remove it from the dryer.
    Remove the screws mounting the console to the dryer cabinet and disconnect the wires from the console.
    Pull the console upward and then forward to remove it from the dryer. Remove the screws securing the display PCB assembly to the console; mount the new one and secure it into position.
    Reinstall the console to the cabinet in reverse of the removal steps and connect the wire harnesses. Slide the top panel back into position and secure it to the rear of the washer.
    Apr 12, 2010 | LG DLE5955 Dryer
    My dryer is not working, a repair man said that
    Its sad to say. But most of the new machine's break in the first 2 to 5 years. your console probably is electronic. I did a washer today that was only 3 years old and had same problem $297.00 for the repair.
    If we can help you with something. let us know. Make sure to give us the model and make of your machine.
    Have a good day
    Jan 09, 2010 | Dryers
    Kenmore 63942 dryer
    remove plastic caps on each end of console by pulling forward at top remove screws in each corner pull console forward and roll back..locate small black relay with 2 blue wires and one with large red wires switch them if dryer works change the one that had blue wires originally if still not working may need to replace even heat board where all those wires go back to ..look for possible burnt spot on it
    Aug 27, 2008 | Kenmore 63942 Dryer
    Kenmore Oasis Dryer - CF codes 01, 02, 03
    Remove the top console (plastic control panel) of the dryer ( 3 screws on the back, tip and slide forward). Inside the console or taped under it should be the tech sheet for the dryer (unless a previous service person did not put it back).
    Read over the tech sheet. In there there will be a section on how to initiate the computer's diagnostic routine. This is typically activated by pressing and holding any button on the console (other than the stop button) for 2-5 seconds, seven times in a row. When activated all the LEDs (lights) on the console illuminate, and then the console displays the actual “F” error/failure codes. In many cases with these Oasis Dryers (model 110.67082600) and similar models the typical one which will be displayed will be F-02 code (even if you got CF 01, 02 and/or 03 before activating the diagnostic routine. F-02 indicates that a button (or possibly several) on the front (user interface) console is simply stuck. If this is the code you get, simply press each of the buttons on the main console and to find which button is indeed sticking (i.e. the one that doesn't work will be the culprit). Save the Stop button for last as that button exits the diagnostic mode, if it is not the one that is sticking.
    The tech sheet (which again shold have been right inside the console housing) explains step by step how to remove the console interface board from the console housing (3 screws and 3 plastic clips). Sometimes simply plaing with the button on the board will get it unstuck, but a simple spray with electronics contact cleaner (which can be purchased at any Radio Shack or other electronics parts store) into the base of the stuck switch on the board, and pressing it quickly a few times will usually do the trick. Once the button is unstuck, no more error code, and the dryer will work fine again. If you can't seem to get the button unstuck (or if it is really damaged), you can either replce the button switch yourself (if you have the electronics and soldering know-how), or buy a new console board from one of the many online parts houses for around $100.
    Again you will need to locate the tech sheet inside the console housing or order one from Whirlpool or Sears for you model for under $10 if yours is missing. Some models vary in what each code means so you will need the tech sheet to be sure.
    Best of Luck Everone...
    Oct 08, 2007 | Dryers
    Follow up on an earlier problem
    I have had the same problem over the past several months. Typically it would clear itself out (clear 8.8. on display) after several minutes. Today it reoccurred but this time it would not clear. I knew it was a problem with the control board. So I removed the control board and discovered that the capacitor for the 5VDC power had ?popped?. I replaced the capacitor and every thing worked! Hope this helps.
    Apr 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
    My Dryer will only work if I hold start button, when start button is released the dryer stops working.
    Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
    Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
    Washing Machines Logo
    11 people viewed this question
    Top Washing Machines Experts
