Question about Panasonic KX-T7667 Phone
Message reorder tone
When i click on message botton a have the message: reorder tone
What does reorder tone mean?
A busy tone (Busy Signal) and a reorder tone are two similar on-off repeating tones that differ in the spped that they beep on and off. Some lay terms for a reorder tone is a Fast Busy tone. Both types of tones use two different frequency tones simultaneously, 480 and 620 Hz, for the beep sound. Busy tones are a half second of tone and a half second of silence, repeated. Today's reorder tone is a quarter second of tone and a quarter second of silence repeated, twice as fast as a busy; a long time ago the cadence was a little different.
May 05, 2014 | Panasonic KXDT343 Phone
I get a "Reorder Tone " message when I dial an extension. How do I fix it?
try PANASONIC website and tech support . we do not fix phone problems here
Oct 03, 2017 | Panasonic KXDT343 Phone
I have a call back on my answer machine but the red light wont go off it comes up with reorder tone I cant retrieve any of my messages I need help?
Press the message button and this will probably ring another extension this must be answered and the light will go out Or Dial *790 This will clear all local settings including call forward To set call forward on busy no answer dial *7105 (destination number) #
Nov 01, 2013 | Panasonic KXDT321 Phone
I have a panasonic TVM50 and the phones are KX-T7633. We wanted to change the message and dialed Intercom 165. Now all we see is "reorder tone" How can we get rid of this and change our personal message?...
The system would have set that 165 are the voicemail ports so the voicemail must be plugged into these ports .usually the last extension on the system Once connected dial 164 then 3. 1. 1 and follow the peompts
Sep 06, 2013 | Panasonic KXDT333 Phone
How do I add my own message tone to phone , I have had the tone sent to me via blue tooth but cant work out how to select and add it as message tone . can only find ring tone , alarm tone and caller tone.
Step1: Click on "applications", then select "My files" Create a folder in the root menu and call it "media"
2. Click on media then create another folder and call it "audio"
3. Click on audio to enter then create the final folder and call it "notifiations"
4. When you have done this transfer your message tones to notification folders
5. Go to message,setting,select ring tones and you will see your files
Hope it helps.
Jun 08, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do you change your message tone
From the phone click on the menu then stroll down to message then click on it then stroll down to message setting click on it,then stroll down to message tone then click on it and view on the message tone available on the phone to peak on the tone you like on your message tone.
Good luck.
Thanks.
Dec 06, 2010 | Samsung B3310 Cell Phone
My motorola i776 doesnt alert me when i get a text message. how do i get it to alert me?
hello,all you have to do is just to access your menu botton,then you go to settings after this you go to sound settings,then under this you see your message alert tone,all you are left with is just to make your choice out of the tones you see there,then you click on it to activate it.thats all on that.thanks,you are highly welcomed.
Mar 09, 2010 | Motorola Mobility i776 Cell Phone
I need to save my text messages to my computer, how do i do it? my ring tones are all corrupt and i need to reset my phone and dont want to lose everything. thanks rob
btw what is the type of your phone? or try these steps move/ transfer it to your mem card or by using pc suite save it to your pc/ laptop.
Nov 08, 2009 | Cell Phones
Text message tone volume, LG KP500, Cookie
Go to Profiles, and choose a Customized Profile. Rename it to whatever you prefer. In this profile you can select your ring tone, message tone, volume, etc. I only had to do this once, and everything worked perfectly!
Feb 11, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Message tones on the samsung u900 soul
go to settings, then choose phone settings. In phone settings go to phone profiles, normal is highlighted click options, then edit, then ok. Click the right arrow then go to message alert tone, click on options then change and ok. Go to use my alert tone choose your tone go to options and click down and select then ok. Then job done.
Jul 13, 2008 | Cell Phones
Open Questions:
See all Panasonic KX-T7667 Phone Questions
Panasonic KX-T7667 Phone Logo
90 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
