Question about Pelco Computers & Internet
MOITOR WILL NOT TURN ON
MONITOR HAS NO POWER
My moitor is powered up but the screen is showing black. I can see very very faint words.what is the problem
chect your bright and contrast controls if they are ok
replace the cold cathode tube power inverter circuit board; it's under the center bottom of your monitor screen
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
Monitors will not turn on due to a power spike. Tower makes a beeping noise with a red blinking light. What could be the problem?
The moitors did not turn on at all after the power spike?
If that is the case, probably some electronic components were burned due to power surge damage.
I advise you to contact the manufacturer for repair and your local electricity supplier.
The beeping noise and the red blinking could be indication that no monitor is plugged in.
Jul 06, 2011 | HP xw6400 Workstation - 2 x Intel Xeon...
Can i use a power cord from a dell moitor i tried but i dont know if its the cord or moitor it was give to me without cord
It uses the same power cord as your PC, NEMA5-15P to IEC C13,
User manual:
http://www.viewsonic.com/assets/027/7939.pdf
It may have problem inside. See failed VIEWSONIC in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 10, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor not working
1.remove and insert the ram again.
if not soved then,
2.Replace the Ram
Jun 21, 2010 | Dell Inspiron E1705 Notebook
My flat panel moitor displays RGB no signal. I
If the other monitor has no signal as well, this proved the video card is faulty and needs to be replaced.
Dec 03, 2009 | Gateway Computers & Internet
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
Blank moitor
can you chk anything abt the lights on the monitor ? ie.. the small ones near the power switch .. is it green / orange ..
Also do u hear any beeps when you power on your computer ? I vaguely remember that in case you hear three beeps, it could be a video card issue.
- Ranjit
Nov 08, 2007 | Dell Dimension 4600 PC Desktop
Display on moitor
just press the auto button on panel it will adjust the screen
Aug 17, 2007 | Compaq FP 7317 17" LCD Monitor
Computers & Internet Logo
47 people viewed this question
Top Pelco Computers & Internet Experts
David Payne
David Payne
Are you a Pelco Computer and Internet Expert? Answer questions, earn points and help others
