Question about Maytag MVWC400XW Washer
Remove the cabinet from a maytag contennial - Maytag MVWC400XW Washer
Replace belt on a maytag med6400tqo
bCheck out a video on youtube. This is a fairly simple do it yourself, but you will need to remove the cabinet of the dryer just leaving the barrel. Remove back cover, remove lint screws. Slide belt between cabinet and barrel. Lay dryer on back and around tension pulley and motor.
Jan 12, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a maytag model MTW5820TWO. I need to replace the water temp switch. How do I remove the console to gain access to the switch?
this video will show you how to open the console(and remove cabinet) disregard the cabinet removal part of the video
Aug 12, 2011 | Maytag Washing Machines
On Maytag dryer model # MDE9316AYA how do I get the top off? One of the fins inside the drum is loose, and I hope I can reach the screws to tighten it up by removing the top, but it won't budge and...
Opening the cabinet of these machines begins with the cabinet top. There are two spring catches located just below the cabinet top that secure it to the rest of the unit. These catches are located towards each side edge. Use a putty knife (or some other thin and flat object) to slide in under the cabinet top to disengage each of the clips. You can now lift up the cabinet top.
With the cabinet top lifted, you will see two screws located inside the top of the cabinet front. Remove each of these screws and lift the front panel to disengage the two clips found at the bottom. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Jun 13, 2011 | Maytag Dryers
Maytag microwave suddenly died after 20 seconds of use - lost all power. Outlet is good. Anyone else experienced this? My cup of tea looks sooo sad - like my wallet... Appreciate your time and...
Replacr the internal fuse you will find when you remove the cabinet. It will be near where the cord enters the cabinet. It is a special fuse ... get a replacement at most hardware of appliance parts stores.
Aug 31, 2010 | Maytag MMV5000 Microwave Oven
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How to remove maytag microwave over the stove about 10 yr old
There is a considerable amount of weight to lower. It is an easier removal with the range pulled out and moved to the side. If you choose to move the range, be sure to protect the floor. Unplug the microwave. The plug should be in the cabinet above the range. There are two screws in the cabinet above that screw down into the top and support the front. These are the only fasteners that hold the machine directly. An assistant would be nice to have to help with the weight. While supporting the microwave, remove the two screws and slowly lower the front of the microwave pulling the cord out of the cabinet above as you go. Once the cord is free, tilt the machine down in front until the back can be lifted up off the plate that is fastened to the wall.
Jul 12, 2009 | Maytag MMV4205 Microwave Oven
How do i change dryer vent direction(from back to bottom)
typically cabinets are screwed together and into the wall. Get a flash light and look for screws in the cabinet, under the cabinet and in the adjacent cabinets
Jun 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Remove front of maytag top load washer
Everyone is different, but the last one i did had screws around the bottom of the cabinet that released the cabinet
Jan 28, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine wont spin anymore
whirlpool made? check the coupler between motor and transmission. Open cabinet by unhooking 2 clips inside control panel and remove entire cabinet.
If its ge or maytag then check belt. Some maytag designs have the belt on bottom (below the cabinet). Other wise use paintscrapper to release 2 clips between top and front panels. front panel comes forward and unhooks from bottom.
Apr 24, 2008 | Washing Machines
Maytag MVWC400XW Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
