Question about Jura Capresso CoffeeTEAM GS 46405
De scaling a Jura capresso coffee team gs
Machine is two years old, to the day! Machine will grind, but not brew. Program light will not go on. Needs descaling?
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
  • 14 Answers
SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Posted on Aug 03, 2008
  • 60 Answers
SOURCE: Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
Posted on Jun 02, 2009
SOURCE: Jura Impressa E fails to dispense, then gives "open tap" message
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
  • 13 Answers
SOURCE: How do I disassemble and clean the brew unit motor
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
How to reset the grinder burrs?
I took the grinder apart and found to have to replace the two metal grinding tools (inside cone and outside ring.
The parts for it were quite cheap. Just get yourself a proper instruction how to do it and follow it religiously. There are marks left by Jura engineers to calibrate the grinder assembly. Changing the actual grinder bits inside does not alter these if put together in the same position. The calibration is essential for a decent taste. After 7 years I would recommend a full service anyway. This will not be cheap, but all seals get replaced or just the brewing unit and the machine will be physically cleaned inside. Only a clean machine will give a decent taste. And the usual cleaning and de-scaling you can do is not enough to maintain a squeaky clean machine over the period of a few 1000 cups of coffee.
Mar 08, 2013 | Jura Capresso Impressa Z5 Espresso/Coffee...
My capresso coffeeTeamGS maker will grind the coffee but will not brew it????
Hi. Your brew unit is by passing the water that is supose to brew. You'll have to clean the brew unit. Jura brewunits are not easly removeable, + you can't buy parts unless your a authorised repairer. Try doing a manual descale cycle. You need to add descale solution to the watertank and operate the hot water and steam functions, which allows the solution to enter the system. Open these functions until water and steam are pumping through, then switch them off and let it sit for a few minutes, then repeat the above 5 or 6 times. This allows the solution to break up any build up. OK, now you have manualy descaled the steam and hot water circuits. Now allow the machine to try and make coffees." we are only trying to clean the machine, so dont drink the coffee." Try 5 or 6 times to see if this is starting to brew better. WE DO NOT LEAVE THE DESCALE SOLUTION IN THE MACHINE. We need to flush the system with fresh water as per above. Descale is corrosive, so we need to get it all out. I hope this has worked for you, other wise you'll have to take it to an authorised repairer. Dazza REPAIRER
Sep 24, 2011 | Jura Capresso CoffeeTEAM GS 46405
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
I have problems with my jura capresso f60, it no longer makes coffee, it grinds the beans, but no liquid comes out. On the screen it says open tap, we have no idea how to fix this.
Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
Mar 30, 2011 | Jura Capresso Jura-Capresso Impressa F60...
Cleaning instructions for jura E8
I am not sure if you are referring to the standard clean that the E8 requests. If that is the case the instruction are to press the rinse button for 5 seconds, until it asks you to remove the tray, then follow the instruction on the screen (they are normally, rinse, rinse, add tablet (should be Jura one) - add to powder shoot, then the process runs through.
If you are talking about de-scale then you should us the Jura de-scale tablets, but vinegar and biccarb can also do the trick.
Feb 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
Oct 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
Take out the tray.
Jul 03, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Unable to make coffee automatically using whole beans
One thought is to call Capresso for the recall to fix electrical cord. They will pay shipping both ways and fix any problems for free as part of the recall. Worked for me, might be too late now but worth trying.
Nov 17, 2007 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso CoffeeTEAM GS 46405 Logo
35 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
