Question about Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Smh9187b replacing door handle - Samsung 1.8 Cu. Ft. Over-the-Range Microwave
Smh9187 microwave stopped working. The units display works, light inside works, vent fan works, but when you put food in it doesnt make a sound.
On model SMH9187B and SMH9187ST, one likely cause is a defective bottom door switch (primary interlock) or that switch's mount is loose, misaligned, or broken. The service manuals for these models are at my site here:
SMH9187B service manual
SMH9187W service manual 1 ' service manual 2
SMH9187ST service manual
Also see my help file on door switches here.
You can order Samsung parts by part number from the Pros here.
If it's not a door switch issue, it may be a blown high voltage fuse not to be confused with the line fuse) or a relay issue on the board, which I can repair for you.
If you have other questions, feel free to contact me at my site below for more free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 18, 2017 | In Microwave Ovens
How to fix a Samsung microwave turntable
The drive motor underneath probably has failed.
Nov 17, 2016 | Samsung Microwave Ovens
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
The door handle on the microwave oven has broke, How do I replace it I have a replacement handle
If you have any questions, please post back and let me know. I hope this helps you.
Dec 22, 2010 | Microwave Ovens
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace door handle
Aug 23, 2010 | General Electric Advantium 120 Microwave...
Replace handle on whirpool microwave
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If you have not purchased a new handle yet, the part number is 4359474 (Black) and 4359473 (White) and costs about $30.
Aug 12, 2010 | Whirlpool MH7135XE Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Samsung 1.8 Cu. Ft. Over-the-Range Microwave Logo
26 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
