Question about Refrigerators
Lg optibin crisper replacement 3806JJ2044
Need to buy replacement door
5 Suggested Answers
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: A sheet of ice forms on the bottom left side of
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 03, 2009
littlepear
  • 7 Answers
SOURCE: Broken Optibin door on LG refrigerator
I got a new bin from repairclinic.com, but the little nubs that hold the bin onto the door (in the thin plastic lining of the door itself) are snapping off. Sigh.
Posted on Jul 06, 2009
MNTECH
  • 1543 Answers
SOURCE: I need to replace the flap door on one of the
Hello Jane. I believe the part you are looking for is a part number 3551JJ2019D, but to be certain, get the full model number off the model / serial number tag from inside the fresh foods compartment of your refrigerator and check with a local service provider (they may even have the part in stock), In the USA, you should be able to find one at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp or contact LG at (800) 243-0000. Cost of the part should be under $15. Regional parts depo's can be found on line at http://www.lge.com/us/support/parts/support-find-parts.jsp
Posted on Aug 01, 2009
I would like to replace the handle of a crisper drawer on kenmore 795.77309600
I think you are referring to the large button that breaks in the front of the two bottom crisper bins? They are not identical with one being slightly larger so you need to know which side. You can go to sears parts . com and put your model in to see a drawing of it and pick the one you need. They list for 110$ and 122$ but you might be able to find them cheaper on another site. The fridge is made by lg for Kenmore so it might say LG or Kenmore when looking at/buying parts.
Jan 23, 2018 | Kenmore Refrigerators
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
I need to replace the flap door on one of the optibins of my LG LFX25960. How do I get that part and what is the cost? Thank you. Jane
Aug 01, 2009 | LG LFX25960 Bottom Freezer French Door...
A sheet of ice forms on the bottom left side of the refrigerator section under the Optibin crisper. It has to remover every 3 or 4 days
Jul 03, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Jun 20, 2009 | LG LRFD25850 French Door Refrigerator
Crisper Door broken
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids.  Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids.  You will need to remove the steel support from the frame before bending the frame.  That is what I have been able to do when I have those problems.
Oct 11, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
