Question about JVC GR-D270 Mini DV Digital Camcorder
Camcorder is saying unit is in safe mode eject and reinsert tape.
I have ejected the tape and left the battery out to reset it but nothing helps. it does this in record mode too
SOURCE:
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
SOURCE: unit in safeguard mode
I have a DVL520U,
I may be lucky from what I have read, but this is what I did.  I took out the tape, released the tension on it by pressing the small tab between the wheels (I observed a slight wheel movement).  I took the eraser end of a pencil, and while holding the tab, rotated the spindles of the tape 10-15 rotations back and forth (this from the vcr days and tracking problems).  I put the tape back in and the problem went away.  I thought of this after reading post after post and then finding the definitions of the error codes on a french website.  Codes 4-6 seemed to be with the mechanical aspects of the drive, codes 1-3 with the sensors etc.  All in all it was a guess on my part.  If any of this works for you, pass it along.
Posted on Oct 12, 2007
  • 12 Answers
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Posted on Jul 04, 2008
welcomejee
  • 10594 Answers
Please remove and reattach battery and hope this will resolve 03 error issue in your JVC camera.
Posted on Dec 06, 2008
SOURCE: unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Posted on Dec 30, 2008
My jvc camcorder shows me a message that my unit is on safeguard mode
E04 is the only one that a consumer can try to rid. This error normally is the fault of a bad tape. I recommend removing battery and HOLD DOWN EJECT, while reconnecting battery so its the first command camera sees. if tapes eject, try a new tape.
Jul 22, 2014 | JVC Video Cameras
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
Vhs tape ejects when pressing record
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Feb 05, 2010 | LG Televison & Video
My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Unit in safe guard mode why , it reads on screen jvc gr-d225e can you help me.also says Eo4 eject and reinsert tape but the tape well not inject when open. help.
I JUNNKED THE CAMCORDER AND GOT A GERMANY CAMERA ; ITS SAD
THAT YOU DID HELP ME WITH THIS LITTLE PROBLEM; NOT EVERTHING IS BASE ON MONEY; I ASK FOR HELP AND YOU ONLY
WONTED MONEY. sad sad
Sep 10, 2009 | Video Cameras
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Unit stuck in safeguard mode
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
66 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
