When I turn on my Viore LC24VXF60PB tv; it comes on with a blank screen for 20 sec; makes a popping sound then turns itself off.
Green light comes on and then after popping noise light turns red and tv is off.
    Problem Solver:
  • 8 Answers
A popping sound is usually caused by a failed power supply. Because of the possibility of fire, unplug the TV and call a service technician or, it the TV has some age on it, shop for a new one. Check out the Consumer Reports ratings before buying a new set. You'll get the best quality TV that way.
Posted on Feb 14, 2014
  • 21 Answers
SOURCE: How to get a picture and sound
if you still have a problem (and the tv!) email me at gmail.com
Posted on Aug 31, 2007
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
  • 4234 Answers
SOURCE: TV shuts itself off..red light blinks 7 times.
The 7 blinks usually indicates a high voltage shutdown situation. Without the specific model, I can;t give you details about parts etc. The options are a defective flyback transformer or problem with the voltage regulation circuits. Please update this with the model number and I'll post additional details as soon as I can.
Thanks,
Dan
Posted on Jan 30, 2009
welcomejee
  • 10594 Answers
SOURCE: The TV PICTURE KEEPS GOING BLANK THEN COMES BACK ON
This is symptom of weak lamp in TV.
How old is this TV and did you replaced lamp recently?
If not, replace lamp in TV to fix this issue.
Lamp light does not lit solid if lamp is not broken or dead.
Lamp replacement procedure is easy and would written in user manual.
Thanks.
Posted on Jan 26, 2010
Broksonic Flat Panel TV, tried to turn back on TV and Green LED light is blinking and screen pops up a few sec with white and colored lines and the turns off
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 21, 2014 | Broksonic Televison & Video
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
When we turn the power on, the green power light goes on, stays on for about 5 secs, turns off, and then turns back on. This happens continuously until we turn off the tv. The screen is blank with no sound...
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)! The backlight inverter is what lites the screen for viewing!
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
Please rate if this helps! :D
Apr 19, 2011 | Sanyo DP37647 37 in. LCD TV
Dec 26, 2008 | LG 42PX5D 42 in. Plasma HDTV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
