Question about Berkeley Berkley Bcdefk Deluxe Electric Fillet Knife
Need blade lock for berkeley electric filet knife
Dewalt instructions
none that style stay locked because your fingers depress button accidentally I like a Sheffield original with the two hinged pieces that fold around blade like Lamborghini doors. The button is bad idea
Jul 14, 2014 | Dewalt Folding Retractable Utility Knife...
Tip
How to choose the right knife for your camping trip
depending on what your plans are for the uses of your knife you will first want to pick either a folding knife which are smaller and can be put in your pocket easy to carry then you have nonfolding knifes that have sheifs which need to be on a belt or put in a backpack pocket there bigger then a folding knife and thicker blade then a folding knife a non folding knife are mostly more stable then folding knives you dont have to worry about the blade folding down on you fingers but most folding knifes have a blade lock just remember when choosing your knife make sure its comfortable to use and not to big bigger is not always better and dont forget a good sharping stone when camping your knife is your life
on Jul 24, 2012 | Camping, Backpacking & Hiking
How do remove the blades from the Rival 1220 model electric knife
I had the same question and finally figured out the answer. To remove the blades on the Rival Electric Knife 1220, first you must locate the piece I am going to refer to as the COLLAR. The collar is located above the "ON" button - toward the blades - but is not part of the blade. It is in between the main machine and the blades and kind of looks like a collar -it also looks like part of the main unit but when pushed from the top will move. On my 1220 it is the same color as the bottom of the machine. Once you locate this secret piece, the rest is quite simple. First-make sure the unit is unplugged then Just place your thumb on top and push the collar down-towards the sharp edge of the blades-and pull the blades out. To reinsert, line the blades up and snap them back into place.
Feb 16, 2013 | Rival Electric Carving Knife
How does an electric knife work?
The way the knife works is that it has two knife blades put together. These blades are serrated (notched). When the power is on, the blades move sideways and basically saw through whatever they are cutting.
Jan 14, 2013 | Home
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I have borrowed an old Black & Decker electric knife that has 2 blades with it. I don't know how to use it? both blades look the same, but you only have one it at one time don't you?
You use both blades together.. On one blade is a (should be) a small metal knob sticking out from the side. On the other is a matching hole. Hold the blades crossed at 90 deg. Lock the knob into the hole on the other and slide blades parrallel, side by side. Both blades should now slip into the slots in handle and lock into place. They will not be exactly level with each other. One will stick out further.. Plug in power, and push run button.. Blades slide back and forth against each other, just hold sharp side against the meat, and push button.. Cuts like butter..
To remove for cleaning, there should be a small button near where the blades lock in, on the bottom (?) push to release blades.. for washing.
Dec 09, 2010 | Black & Decker Black Decker Slimgrip...
Stanley 10-801 utility knife. How do you change the replaceble blade?
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Nov 26, 2010 | Stanley Garden
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
Berkeley Berkley Bcdefk Deluxe Electric Fillet Knife Logo
540 people viewed this question
Top Berkeley Home Experts
Donni Steen
Tom Chichester
Are you a Berkeley Home Expert? Answer questions, earn points and help others
